06-06-2016 12:50 AM
Hi guys,
will there be a drag&drop option in Jabber? I would like to move people between the groups.
Additionally I lack (I think everyone does) integration with Active Directory where I can add groups that report to certain managers.
Please advise if there are plan for improvements of MS Lync is still better in this area...
Aleks
06-06-2016 03:28 AM
The answer is no
Drag&drop is used to add new participants to chat group or transfer call in version 10.5 and later.
06-06-2016 03:35 AM
Lior,
Thank you for a quick replay. I have 11.6 and it does not work. Maybe I was not precise. Drag and Drop for me means to click one- left mouse click- contact and moving it to other group. Please see attached. I want to move my friend Anika from one group down, by dragging and dropping- does not work.
Aleks
06-06-2016 05:59 AM
again, for moving users between groups, the only way is to do this with right-click->move to group... (something like that).
drag&drop for this case is not supported.
looks for "drag and drop" in the release node for 11.6 version:
06-06-2016 06:05 AM
on the AD group are you familiar with the 11.x sync with AD group feature or is that lacking for you?
