Drag&Drop opton in Jabber
adutkows
Hi guys,
will there be a drag&drop option in Jabber? I would like to move people between the groups.
Additionally I lack (I think everyone does) integration with Active Directory where I can add groups that report to certain managers.
Please advise if there are plan for improvements of MS Lync is still better in this area...
Aleks
lior look
Contributor
Contributor
The answer is no
Drag&drop is used to add new participants to chat group or transfer call in version 10.5 and later.
Lior,
Thank you for a quick replay. I have 11.6 and it does not work. Maybe I was not precise. Drag and Drop for me means to click one- left mouse click- contact and moving it to other group. Please see attached. I want to move my friend Anika from one group down, by dragging and dropping- does not work.
again, for moving users between groups, the only way is to do this with right-click->move to group... (something like that).
drag&drop for this case is not supported.
looks for "drag and drop" in the release node for 11.6 version:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/11_6/jabw_b_userguide-for-ciscojabberwindows-116.html
on the AD group are you familiar with the 11.x sync with AD group feature or is that lacking for you?
Recognize Your Peers
