12-17-2014 10:43 AM
I've recently used the DX series SDK and successfully tested the example android applications. However, I'm trying to see if it's possible to send audio from an inputstream type into a Cisco call.
When I searched online I found that a normal Android device does not allow of modification of the outgoing audio in a call. You can only switch between physical microphone sources or possibly a bluetooth headset.
My question is:
Is there any way that I can send audio from a local file or inputstream type to the receiver end of a call on a DX70? I'm open to creative solutions.
Thanks for the help!
Solved! Go to Solution.
03-06-2015 12:23 PM
I've moved this post to the DX Series Community space so that developers following that space can reply to your post.
03-06-2015 12:23 PM
