Error in compiling Remote Expert AssistSDK -
In Xcode 7.2.1 , I am getting error when I compile project which says :-
Undefined symbols for architecture x86_64:
  "_OBJC_CLASS_$_AssistSDK", referenced from:
      objc-class-ref in VideoCallViewController.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
This is what currently I have for architecture settings perspective in my App  :-
  Architectures : Standard Architectures(armv7, arm64) - $(ARCHES_STANDARD)
  Base SDK : Latest iOS(9.2)
  Valid Architectures: arm64, armv7, armv7s
  IOS Deployment Target: iOS 7.1
Hi Prashant,
There is no way to change the video screen size on iPhone.
This discussion is titled "Error in compiling Remote Expert AssistSDK".
For further unrelated questions please raise in a new discussion.
Rob
8 Replies 8
robdoyle
Hi Prashant,
Strange as you are not defining x86_64 support.
Can you build just for the current device and not use a simulator?
x86_64  support should be in REM 11, due out at the end of April, last I heard.
Rob
Thanks, it is building on device.
Is there any way to run the build on simulator ?  I am getting 6 errors like when i am running on simulator :-
"webrtc::RtpExtension::IsSupported(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
cricket::FilterRtpExtensions(std::__1::vector<cricket::RtpHeaderExtension, std::__1::allocator<cricket::RtpHeaderExtension> > const&) in ACBClientSDK(libjingle_media.webrtcvideoengine2.o)
"webrtc::VideoDecoder::Create(webrtc::VideoDecoder::DecoderType)", referenced from:
cricket::WebRtcVideoChannel2::WebRtcVideoReceiveStream::CreateOrReuseVideoDecoder(std::__1::vector<cricket::WebRtcVideoChannel2::WebRtcVideoReceiveStream::AllocatedDecoder, std::__1::allocator<cricket::WebRtcVideoChannel2::WebRtcVideoReceiveStream::AllocatedDecoder> >*, cricket::VideoCodec const&) in ACBClientSDK(libjingle_media.webrtcvideoengine2.o)
Can you please give me a link to REM 11 Version for iOS of Remote Expert Mobile ?
Hi Prashant,
REM isn't supported to run on simulator.
As previously mentioned, REM 11 is due out at the end of April.
Rob
Thank you very much Rob for your assistance.
How can i increase the Video Screen size on iPhone?
Hi Prashant,
Rob
Hi is way to change the video screen size on web ? I am using client SDK for web.
Hi Lukasz,
As you know this is answered at Remote Expert Web Fullscreen
All thre best,
Rob
