Extension mobility API: clearing call history and rate limit.
floatingpurr
So, I'm trying to build an Extension-mobility-API-based service with a CUCM 11.5 cluster. I have 2 questions:
  1. Since I have to deal with ~4k devices with relative login/out events, I need to know if there is any limitation on the number of requests that the Extension mobility API can handle per time unit. I haven't found any reference about it so far.
  2. As per the doc, it looks like there is no way to automatically delete the device call history upon logout. The param "Clear Call Logs on Intra-Cluster EM" seems working just for manual logouts. Is there a way to clear the call history without relying on workarounds with the AXL? It's a pretty common use case, after all.
Thanks!
