Extension Mobility API doesn't logout with CUCM 12.0
Flexcom99
I try to make a logout thanks to EM API : it works with CUCM 9.5, 10.5, 11.5 but not with CUCM 12.0.
The logout request is :
<request>
    <appInfo>
        <appID>admin</appID>
        <appCertificate>XXXXXXXX</appCertificate>
    </appInfo>
    <logout>
        <deviceName>SEP0123456789AF</deviceName>
    </logout>
</request>
and the response is (with an HTTP 200 status code) :
Error processing request: null
The request is send to http://CUCM12IP:8080/emservice/EMServiceServlet with Content-Type: application/x-www-form-urlencoded thanks to a POST method (GET is tested also but doesn't work too). All others API calls work (login, userDevicesQuery, deviceUserQuery...).
I would like to know what has changed in the EM API for that particular version of CUCM ?
19 Replies 19
Thanks for the continuing investigation @dstaudt. Making it backward compatible would be ideal.  Is there a CSC bug ID# for this yet that you know of?
The link refers to EM login. How is this applicable to EM logout?
Also, this is producing a http 500 error, that would not be the case with just a missing variable. Also, Cisco own sample login page does not work. This is a bug not matter how you slice it.
Hi, I check it in bug tool, it is fixed in the patch (1.23033.1), correct?
thank you !
I've heard 2nd hand that private bug# CSCvn48861 is created for this. Wondering if @dstaudt can confirm and provide any updates or timeline for a fix.
I've confirmed that the issue no longer exists in CUCM 12.5.1.10000-22
