FIle transfer using cisco jabber web sdk
shahhuss
HI
  Is there any way that i can do file transfer  using cisco ajax xmpp library .
appreciate the suggestions .
tinghche
Level 5
Level 5
Hi Mohammed,
Sorry, the file transfer feature is not current implemented in CAXL.
Will update you if there is any plan in the roadmap.
Howard
tinghche
Level 5
Level 5
Hi Mohammed,
Howard
