Hide Contacts in Jabber Client
marwa.ads
Hi All,
is there an API that i can use to programmatically hide contacts at the Jabber desktop Client for specific users?
I know i can do this manually from the Jabber desktop Client, I need an API for this.
Thanks.
dstaudt
Unfortunately there are no APIs for configuring/controlling the Jabber clients.  I don't know how the configuration preference is persisted in the system, but if it is stored in the registry or in a disk config file, you may be able to make the change directly via an application...
