IM based Desktop Sharing
vvazquez
I read that Jabber SDK supports BFCP based (while in a video call) desktop sharing. What about IM based desktop sharing? Customer would like to share the desktop without the need to establish the call first.
Victor
Edwin Vos
Level 4
Level 4
Hello Victor,
The IM only desktop share has been released on the full client, since about release 11.0, see snippet below from the Cisco Jabber 11.0 Planning guide. As you can see this is only windows to windows IM initiated desktop share and not Windows to Macintosh.
I have not seen any indication that the Jabber API's have any more functionality on this than the full client/server setup. So all in all you might be able to find the windows to windows IM based desktop sharing within the SDK, but I seriously doubt it, seeing that this feature has not been around on a lot of Cisco Jabber versions yet.
Cisco Jabber 11.0 Planning Guide - Screen Share [Cisco Jabber for Windows] - Cisco
IM Only Screen Share
Applies to Cisco Jabber for Windows.
IM Only screen share is a one to one screen share and is enabled using the EnableP2PDesktopShare parameter in the jabber-config.xml file. In a chat window users select ... > Share screen.
The port range for this option is 49152 to 65535 and this can be reduced by using the SharePortRangeStart and SharePortRangeSize parameters in the jabber-config.xml file.
Cheers,
Edwin
