IPPS - <CiscoIPPhoneImageFile>
DaWoonKim9516
Hello
An image was output to the phone using the <CiscoIPPhoneImageFile> in the XML Object.
If the value of the <LocationY> element is 0, the image is at the bottom, so I want to raise it to a medium level.
If the value of <LocationY> is lowered below -1, an HTTP 400 Error response is received.
Can I raise the image to the middle without using the <Prompt> element?
The IP Phone is model 8841, 8851 and is using size 559 X 265.
Thank you!
dstaudt
Per the IPPS docs, the LocationY=0 should place the top of the image at the top of the display - you can then add to this to move the image downward, or specify -1 to have it centered (vertically.)  Values less than -1 are not allowed.
If you are observing that LocationY=0 seems to position the image at the bottom regardless - that sounds like a possible bug.  A few things to try/check:
* Test with an image that is definitely smaller in resolution than the target display area (which is smaller than the physical LCD display size), just to make sure that auto-resizing is not coming into play
* What happens if you use positive values for LocationY?
* Are you using/have you tried the 'Normal' and 'Wide' display options?
When the LocationY value is set to positive, the image goes down.
I haven't used the 'Normal' and 'Wide' options.
I don't think it's a bug. It appears in the same location as the link below.
https://community.cisco.com/t5/audio-and-video-endpoints/ciscoipphoneimagefile-for-8851/td-p/3535258
However, I want to raise the image a little more.
If the locationY negative value is not available, can I raise the image up in another way?
Testing with a 7975, this is what I see for LocationY values of 0, 50, 100:
Displayed image:
XML posted:
    <Title>Image File Object</Title>
    <Prompt>Image File Object</Prompt>
    <LocationX>0</LocationX>
    <LocationY>100</LocationY>
    <URL>http://{image server}:8080/Youngkitten.png</URL>
</CiscoIPPhoneImageFile>
LocationY = 0:
LocationY = 50:
LocationY = 100:
With LocationY = 0, the image is pretty much all the way to the top...if this is also what you're seeing, I'm not sure what you mean by 'raise the image a little more'..?  If you want to raise it so that the top part of the image is 'off screen', you may need to pre-crop the image on the server-side before displaying it.
Image with locationY of 0.
Could it invade the prompt layout and raise the image up?
