Is there a way to "record" a greeting through Unity Connection API?
fabien.bonic
Level 5
Level 5
On the Unity Connection administration GUI, it's possible to "record" a greeting (System Call Handler > Edit Greeting). Is there a way to do the same thing using a Unity Connection API (by uploading a file for example)?
Fabien
lindborg
yes - Connection's REST API allows uploads of all greetings and voice names from WAV files - Cisco Unity Connection Provisioning Interface (CUPI) API -- Index of All CUPI Documentation - DocWiki
you can also use TRAP (telephone record and playback) to record greetings via the REST API as well - if you're a C#/.NET house you can use the .NET SDK for CUPI that has examples on how to do both these things reasonably easily.
REST .NET SDK
lindborg
REST .NET SDK
Thank you for this answer. I will try these requests REST
