Issue on Jabber using iPhone 6S Plus - Speaker
I'm using Jabber on my iPhone 6S Plus. Placing the device next to my ear I have no problems,  but when I want to use the Speaker, it doesn't work. I listen to the other person, but on the other side no body listens to me.
What should I do?
dstaudt
This forum is for developers using Jabber SDKs and APIs to build applications - it sounds like you may be having an issue with the Jabber mobile client itself.
You might try the product-centric forums here: Unified Communications
however your best bet would be to open an issue via your established Cisco CUCM support channel.
