Jabber Connect Error: Not Authorized
jmennear
I have having trouble identifying why the XML API is returning an error on "Connect".
The code I am using is pretty simple:
<script src="http://code.jquery.com/jquery-1.4.2.js"></script>
        <script type="text/javascript" src="caxl/jabberwerx.js"></script>
        <script type="text/javascript">
           var client = new jabberwerx.Client('safeway');
            var connectArgs = {
                // the proxy url to the BOSH server
                httpBindingURL: 'https://cisco ACE cup server:7335/httpbinding',
                // onConnected is the success callback method
                successCallback: onConnected,
                // onClientError is the error callback method
                errorCallback: onClientError
        function login() {
            var username = document.getElementById("username").value;
            var password = document.getElementById("password").value;
            client.connect(username, password, connectArgs);
            $("#log").append( "<br>attempting to connect");
        function onConnected(event) {
            $("#log").append( "<br>connection successful");
            client.sendPresence('away', 'gone to lunch');
            $("#log").append("<br>set as away");
        function onClientError(event) {
            var data = event.xml;
            data = data.replace(/</g, "&lt;");
            data = data.replace(/>/g, "&gt;");
            $("#log").append( "<br>connection not ssuccessful: " + data);
        </script>
My Jabber server is a 9.7 and the jabberwerx.js file has a version stamp of 8.7.6.
Could this be a version issue?
-john
It turned out the problem was that
The end user was assigned to different CUPS node that is not the same as the BOSH URL we are trying to request.
Assign the end user to the corresponding node has fixed the problem
Howard
jmennear
Based on some of the other comments I see in the forum I have replaced the server name with the ipaddress of the server.
"<stream:error xmlns:stream="http://etherx.jabber.org/streams"><xml-not-well-formed xmlns="urn:ietf:params:xml:ns:xmpp-streams"/></stream:error>"
This change has made it so that a previous error of "Not Authorized" has been replaced with this new error of "xml-not-well-formed".
I am using sample code to run against an ACE program server within Cisco IT.
Howard
