06-23-2015 01:22 AM
It is possible to run widget in iframe with turned off camera ? How can I do that ?
Solved! Go to Solution.
06-23-2015 11:25 AM
Yes...the Jabber Guest call widget should load and work fine (one-way video, of course) with camera disabled (or not existing...)
06-23-2015 11:25 AM
06-23-2015 11:50 PM
Ok but I'll want turn on camera when the conversation is in progress. I want use only this part of widget, can I control this from javascript code ?
