Jabber Guest for Android SDK Now Available in Jabber Guest Early Adopter Program!
Christopher McAlpin
Community Manager
Community Manager
To join the Jabber Guest Early Adopter Program Trial:
You must join the Cisco Customer Connection Program (CCP) first if you haven’t already, and then you will have access to the Private - CCP space where you can register for the Jabber Guest Early Adopter Program trial.
Getting Started:
1.    Please go to the CCP public landing page: www.cisco.com/go/ccp
2.    If you are already a CCP member, login with your cisco.com (CCO) ID.
3.    If you are not currently a CCP member, follow the instructions to join the CCP and then return to step 1 above.
4.    Once you’ve logged in, click on the link “Go to the private member community”.
5.    Once you are in the Private – CCP space, click on the “Access & sign up for trials” button in the Early Adopters and Beta Trials section.
6.    Select the Jabber Guest trial, read the requirements, and register for the trial.
All the best,
Christopher McAlpin
Early Adopter Program - Customer Engagement
Cloud Collaboration Technology Group
Cisco Systems
0 Replies 0
