Hi all!
I am new in Jabber Guest SDK for iOS and try to integrate a Guest Call functionality into the App.
I would like to use method configure(from: URL) instead to set properties serverName and toUri in order to provide later the caller name as http-parameter callerName within a guest call. Here is the simple example:
@IBAction func startCallButtonPressed(_ sender: UIButton) {
print("Start video call pressed")
let guestCallUrlString = "https://jabberguestsandbox.cisco.com/call/5555"
let call:CJGuestCall = CJGuestCall.sharedInstance()
var jabberG: CJGuestCallViewController? = CJGuestCallViewController()
if jabberG != nil {
print("Init Jabber Guest")
let guestCallUrl = URL(string: guestCallUrlString)
jabberG?.configure(from: guestCallUrl)
self.present(jabberG!, animated: true, completion: nil )
So, if I run this example, I get the never-ending message "Checking connection...", it looks like the GuestCallViewController is not configured.
If I try to set the URL via property fullServiceUrl instead using configure(from: URL),
if jabberG != nil {
jabberG!.fullServerUrl = guestCallUrlString
I got an error "No server connection. The Jabber Guest server is not reachable".
The only way that works is to set the properties
if jabberG != nil {
jabberG!.serverName = "jabberguestsandbox.cisco.com"
jabberG!.toURI = "5555"
but in this case, I have no chance to provide the caller name like https://jabberguestsandbox.cisco.com/call/5555?callerName=Alice
What is wrong? Any idea?
