Jabber Guest SDK for iOS: CJGuestCallViewController.configure(from: URL)
vm21
Hi all!
I am new in Jabber Guest SDK for iOS and try to integrate a Guest Call functionality into the App.
I would like to use method configure(from: URL)  instead to set properties serverName and toUri in order to provide later the caller name as http-parameter callerName within a guest call. Here is the simple example:
@IBAction func startCallButtonPressed(_ sender: UIButton) {
        print("Start video call pressed")
        let guestCallUrlString  = "https://jabberguestsandbox.cisco.com/call/5555"
        let call:CJGuestCall = CJGuestCall.sharedInstance()
        var jabberG: CJGuestCallViewController? = CJGuestCallViewController()
        if jabberG != nil {
            print("Init Jabber Guest")
            let guestCallUrl = URL(string: guestCallUrlString)
            jabberG?.configure(from: guestCallUrl)
        self.present(jabberG!, animated: true, completion: nil )
So, if I run this example, I get the never-ending message "Checking connection...", it looks like the GuestCallViewController is not configured.
If I try to set the URL via property fullServiceUrl instead using configure(from: URL),
if jabberG != nil {
            jabberG!.fullServerUrl = guestCallUrlString
I got an error "No server connection. The Jabber Guest server is not reachable".
The only way that works is to set the properties
if jabberG != nil {
           jabberG!.serverName = "jabberguestsandbox.cisco.com"
           jabberG!.toURI = "5555"
but in this case, I have no chance to provide the caller name like https://jabberguestsandbox.cisco.com/call/5555?callerName=Alice
What is wrong? Any idea?
0 Replies 0
