Jabber SDK for Web - hung on Windows 10
palmerstown
I'm having a problem running the sample.html from the Jabber SDK for Web, on Windows 10 & IE11. When the page first loads, a blank command window appears in front of it, titled CiscoWebCommunicatorAddOn.exe and remains on-screen. You can send it to the background by clicking on the browser window, but the web page is not functional.
BTW I have successfully used the SDK sample.html on Chrome on this machine.
Also this machine did have the full Jabber client installed on it, but I removed it & rebooted, in case that was the issue. It didn't solve the problem though.
Software versions:
- Windows 10 Home v1803 Build 17134.765
- Internet Explorer 11.765.17143.0 (update 11.0.125)
- Jabber SDK browser add-on 11.8 MR2
palmerstown
It turns out this was happening because 'protected mode' was enabled on IE11. Its not compatible with the Jabber SDK. To disable it in IE11, go to Internet Options -> Security -> Enable Protected Mode (clear this box). Then restart the browser.
palmerstown
