Login errors
Bill Durrant
Trying to login from the basicChatDemo and getting the following
Could not connect: <stream:error xmlns:stream="http://etherx.jabber.org/streams"><service-unavailable xmlns="urn:ietf:params:xml:ns:xmpp-streams"/></stream:error>
CUPS 9.1.1
Verified I adjusted teh basic-chat correctly, tried tweaking the BOSH url with no luck.  Any thoughts?
Figured this out, I didn't have my web connection manager started.  Working now.
npetrele
Check your BOSH URL by navigating to it in your browser directly.  In other words go to https://somedomain.com:7335/httpbinding in your browser (or use http if you're not set to use a secure BOSH URL).  You should see this (below).  If you don't see this, report back what it is you see.  The most common problem is that the browser isn't set to accept the server security certificate, and you'll get an error about that.  Once you accept the certificate, the demo should work.
