Macro for swaping monitors (Cisco Room Bar / Codec Pro)
silvakizir
Hi to everyone.
We had implemented in the past the Macro from the bellow link to the Codec Pro registered with Webex and it was working successfully .
https://community.cisco.com/t5/telepresence-and-video-infrastructure/macro-to-swap-monitors-connecting-to-room-kit-plus/td-p/4435811
Approximately 2 weeks ago it stopped working and my guess is that something changed maybe after an upgrade in the version of the OS which was released on January 2024.
I also tried the Macro in the Cisco Room Bar registered with Webex which has the same exact OS version and it doesn't seem to work.
The running version of both the codecs currently is the below.
Can anyone help? Thanks in advance.
Jonathan H
Experienced this issue using that same macro, and the runtime error we're getting is 2024-05-08 19:37:01Swap monitorsReferenceError: 'require' is not defined at <anonymous> (./Swap monitors:2)
Looking at any updates in the roomos to see if it's just a syntax issue
I suspect this is due to the deprecation of the CommonJS module specification in favor of ES modules: https://roomos.cisco.com/doc/TechDocs/MacroTutorial#modules
This is hopefully a fairly easy refactor, e.g.: https://electerious.medium.com/from-commonjs-to-es-modules-how-to-modernize-your-node-js-app-ad8cdd4fb662
