01-29-2024 11:25 PM - edited 01-29-2024 11:26 PM
Hi to everyone.
We had implemented in the past the Macro from the bellow link to the Codec Pro registered with Webex and it was working successfully .
Approximately 2 weeks ago it stopped working and my guess is that something changed maybe after an upgrade in the version of the OS which was released on January 2024.
I also tried the Macro in the Cisco Room Bar registered with Webex which has the same exact OS version and it doesn't seem to work.
The running version of both the codecs currently is the below.
Can anyone help? Thanks in advance.
05-16-2024 10:39 AM
Experienced this issue using that same macro, and the runtime error we're getting is 2024-05-08 19:37:01Swap monitorsReferenceError: 'require' is not defined at <anonymous> (./Swap monitors:2)
Looking at any updates in the roomos to see if it's just a syntax issue
05-16-2024 11:38 AM
I suspect this is due to the deprecation of the CommonJS module specification in favor of ES modules: https://roomos.cisco.com/doc/TechDocs/MacroTutorial#modules
This is hopefully a fairly easy refactor, e.g.: https://electerious.medium.com/from-commonjs-to-es-modules-how-to-modernize-your-node-js-app-ad8cdd4fb662
