Problems embedding Jabber Guest Widget in Google Chrome
dmcsweeney1
Hi-
I'm having trouble embedding a very simple Jabber Guest Widget in an HTML file for Google Chrome for MAC.  The same HTML code works without any problems in Firefox and Safari.   Here is the code:
<!DOCTYPE html>
<html lang="en-US">
<div>
    <iframe id="jabberc" src="https://servername/call/dialstring?widget=true" width=640 height=430>
    </iframe>
</div>
</html>
With the other browsers, I see my local video window as expected and when I press the call button the call goes through normally.
With Chrome, I see no local video in the widget, but the call button does appear.  When I press the call button, the call goes through, however there is no video rendered in the widget.
When I select "Inspect Element" in the Chrome window, I am seeing what appears to be an initialization problem in the Cisco Jabber Guest Extension for Chrome  as shown in the screenshot of the console window:   It appears to be constantly in the state of "Sending initialize to parent".   This goes on until I close the window.
If I open the widget in a new window instead, I see the local video as expected and the video renders properly when in the call.
Here is the version information about the Jabber Guest Environment.   Any suggestions?
Cisco Jabber Guest: main_10.5.3.115
Cisco Jabber Guest Add-on: 10.5.3.73
Cisco Jabber Guest Extension (for Chrome) 10.5.3.11
20 Replies 20
npetrele
If I recall correctly (I may not, my memory isn't what it used to be, also, my memory isn't what it used to be), you need to use a pop-up window in Chrome rather than an iframe.  I'm checking on that.
Thanks for checking.  I should have mentioned that a colleague has been able to make it work on Windows/Chrome without needing a pop up window.  At some point earlier on in her development though, she was experiencing a similar issue.
I checked with the team, and it should be possible to put the video in an iframe.  I'll investigate further and let you know what I find out. By the way, have you installed both the Chrome Jabber Guest add-on and the Cisco Web Communicator 3.1.0.363 Chrome add-on?
Thanks Nicholas-
For chrome, the two items I needed to add (both automatically prompted by the Jabber Guest widget) were Jabber Guest Extension for Chrome and then the Jabber Guest Add-On for MAC.  I was not prompted to download/install the Cisco Web Communicator.
Best-
Dave
Good Morning Nicholas-   Just checking in on our conversation from last week, I'm curious if you've discovered anything from my report on Jabber Guest and Chrome.
Many thanks!
Dave
I guess my memory isn't as bad as I thought.  The latest Jabber Voice/Video requires that the video must be in a separate (pop-up) native window when you implement it in Chrome.  I assume this applies to Jabber Guest, too, since the underlying technology is the same.
That's correct...Chrome no longer supports the ability for extensions/add-ons to embed something like a video window directly.
However, I understand the new SDK supports the ability to 'pin' the video window to the browser page in such a way that it stays on top and always in the same place relative to the page contents - mimicking the experience of an embedded video window.
Well, I've been able to embed the Jabber Guest widget into a web page along with the rest of my application. It works great in Chrome on the PC but my colleague can't get it to work on the Mac. (It launches the video in a separate window, eventhough the iframe is embedded in the page with the call button included. Once you click the Call button the video pops open in another window - again, this issue is on the MAC only.)
Thoughts?
Corinne
Thanks for the responses.  Hmm...I'm a little confused since we do have a embedded Jabber Guest window working on a Windows PC/Chrome setup, but the same code is not working in my MAC/Chrome.
That said, when you say the new SDK supports the ability to pin the window- is this the 10.6 update slated for release this summer?
Dave
The pinning/docking behaviour for the video overlay window should be in 9.3(2)MR2:
https://developer.cisco.com/site/jabber-websdk/develop-and-test/voice-and-video/downloads-and-docs/release-notes-3.1.2/
On your windows/chrome setup, is it possible that a pre-NPAPI-deprecation version of chrome is present, or the Jabber NPAPI plugin has been whitelisted?  I.e. are we sure the chrome add-on is being activated/used?
The information you sent along is about Jabber SDK. My question is related to Jabber Guest SDK. Does this impact your answer/input?
If not, please let me know how to check on the version of Chrome for Windows that would apply to pre-NPAPI-deprecation and I can check.
Dave
Yes, I was thinking of Jabber vs. Jabber SDK on the docking behaviour...I don't immediately see anything on the JG docs that covers the difference in behaviour.  We'll investigate further...
In what version of Jabber Guest plugin-addon/Chrome/OSX/Windows/32v64bit are you seeing the embedded vs. popup behaviour?
In the scenario that is not working:
  • Mac OSX 10.10.2
  • Cisco Jabber Guest: main_10.5.3.115
  • Cisco Jabber Guest Add-on: 10.5.3.73
  • Cisco Jabber Guest Extension (for Chrome) 10.5.3.11
  • Chrome Version 43.0.2357.81 (64-bit)
Corinne is following this thread and will respond with the Windows/Chrome/etc versions that are working properly.
And in the scenario that IS working, I am using:
  • Windows 7 Enterprise (Version 6.1 - Build 7601: Service Pack 1)
  • Google Chrome Version 43.0.2357.81 m
Please let me know if you need any other info.
Corinne
