02-04-2014 10:33 PM
I have a requirement, where i need to publish/feed Text alerts to IP Phone and Communicator dynamically. It could be really helpful, if i could have inputs (documents/samples) to achieve this requirement.
Thanks & Regards,
Prabodh Panda
02-06-2014 02:26 AM
I am working on the same issue. I found something but couldnt make it work. I tried to push the following script below to the phone through its CGI:
<CiscoIPPhoneText>
<Title>Title text goes here</Title>
<Prompt>The prompt text goes here</Prompt>
<Text>Hello World</Text>
</CiscoIPPhoneText>
Unfortunatelly, it didnt work. Am I missing something? I mean obviously yes but can anybody help and point me to the right direction?
02-06-2014 03:05 PM
Hi Prabodh,
You can find the latest developer guide on devNet
https://developer.cisco.com/site/collaboration/endpoints/ip-phone-services/documentation/
If you could specify what are you trying to achieve here, so that the forum can help.
Szilard,
You can download the SDK from the same url above, there are some pretty good example for you to follow.
Hope this help
Howard
02-06-2014 09:25 PM
Hi Howard,
Thank you for the reply.
To be precise in my requirement, I could need to PUSH notification/alerts from my hosted service to IP Phones. If during any emergency if the hosted services receives a alert message, it need to PUSH/broadcast these alerts in to IP Phones.
Please let me know if any any other information.
Prabodh Panda
02-07-2014 01:27 AM
Ting-Hao,
I managed to send and authenticate commands to the phone via CGI. Example I can set the background of the phone by pushing the buttons remotely. My problem is that I am unable to send simple text message. The one I used above doesn't work.
Any idea what I might missing?
regards,
Szilard
02-07-2014 10:24 AM
The CiscoIPPhoneText object as above should be what you want. It may be helpful to look at a network packet capture (i.e. Wireshark) of the HTTP request/response to the phone, to ensure the raw data is as expected. Feel free to post the pcap here if you don't spot the issue.
https://developer.cisco.com/site/collaboration/endpoints/ip-phone-services/wiki/openingsteps/
07-08-2014 08:18 AM
Hi Prabodh,
We're currently have a requirement similar to what you need to accomplish. Have you solved it? Could you share how did you do it? We cannot send any push to the ip phones, neither text nor images... nothing.
Any tip or trick can you share with us?
Regards.
Saul Benavides
