QuickSet SX20 Replacement Camera Cable
rajanmant
Are CAB-HDMI-PHD4XS2 and CAB-HDMI-PHD4XS (without a "2" in the end) same and/or interchangeable? We have a CTS-SX20-PHD4X-K9 which came with CTS-PHD1080P4XS2+ camera and the camera cable has gone bad. Original cable was CAB-HDMI-PHD4XS2 and want to know whether CAB-HDMI-PHD4XS will also work.
Appreciate if anyone can confirm.
Anurag Srivastava1
I think it is same you can connect and try.
Also please see the below link-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
Page 18
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
Thank you Anurag. Yes. I had already seen that document and physically they look the same. Will try as per your suggestion.
