03-28-2017 08:53 AM
Can anyone clarify what is the source of the value returned from the getRemotePartyDisplayName method? I've set my display name and validated in the REAS call logs that it is being sent in the 200 ok Response. Is there somewhere else I should be trying to force this value in the SIP headers? Here is the 200OK. I would hope to return the "CCX Queue" value from my method call:
2017-03-28 11:41:20,667 : Inbound Message
Transport: TCP: ip=10.122.23.138, port=5060, secure=false
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.122.23.142:5080;branch=z9hG4bK8dd513fb-969b-47e3-9676-4bd40200d5a5_3_e897ac49_56148172222920_0
From: "Brad Cason" <sip:assist-BradCason@iland.com>;tag=0-mobi-93021523_ada14cd5_50e89fc8-3b07-440d-a353-8ab5a9dd4c57_3
To: <sip:50020@10.122.23.138>;tag=454755~414f568f-51c0-4fba-8a77-9858a32b6d3d-23006838
Date: Tue, 28 Mar 2017 15:41:20 GMT
Call-ID: ea57bf6679ed29eaf218dab09b6bf201@10.122.23.142
CSeq: 1 INVITE
Allow: INVITE,OPTIONS,INFO,BYE,CANCEL,ACK,PRACK,UPDATE,REFER,SUBSCRIBE,NOTIFY
Allow-Events: presence,kpml
Supported: replaces,X-cisco-srtp-fallback,Geolocation
Server: Cisco-CUCM10.5
Call-Info: <sip:10.122.23.138:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-Expires: 10800;refresher=uas
Require: timer
P-Asserted-Identity: "CCX Queue" <sip:50011@10.122.23.138>
Remote-Party-ID: "CCX Queue" <sip:50011@10.122.23.138>;party=called;screen=yes;privacy=off
Contact: <sip:50020@10.122.23.138:5060;transport=tcp>
Content-Type: application/sdp
Content-Length: 352
v=0
o=CiscoSystemsCCM-SIP 454755 1 IN IP4 10.122.23.138
s=SIP Call
c=IN IP4 10.122.23.134
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 25092 RTP/AVP 0
a=ptime:20
a=rtpmap:0 PCMU/8000
m=video 0 RTP/AVP 31 34 96 97
a=rtpmap:31 H261/90000
a=rtpmap:34 H263/90000
a=rtpmap:96 H263-1998/90000
a=rtpmap:97 H264/90000
a=content:main
a=inactive
03-29-2017 03:56 AM
I guess I should add that when I call getRemotePartyDisplayName it returns an empty string. I am calling it in the onInCall callback. I've also tried setting a timer and waiting a couple seconds after the onInCall callback with the same results.
03-31-2017 12:35 PM
still messing around with this...also tried setting up the onRemoteDisplayNameChanged callback and attempting to get the value in there, but that callback is never triggered. Anyone have any ideas?
04-10-2017 10:44 PM
Hi Bradley.
Could you share with us the code you are using to make the call so we could take a quick look?
Cheers,
Rach D
04-12-2017 11:42 AM
I've tried it a few different ways but here's my latest attempt. There seem to be two issues. The first is that the "onRemoteDisplayNameChanged" callback never fires. But when I take the getRemotePartyDisplayName outside of that block and just call it manually, for example when the onInCall callback fires, it just returns an empty string.
call.onRemoteDisplayNameChanged = function () {
remoteParty = call.getRemotePartyDisplayName();
04-13-2017 12:53 AM
Thank you for the reply Bradley, That is strange, we've not encountered this in our testing so far. Would it be possible for you to share a fuller code snippet with us so we could take a look?
Do you hard code the SIP address into the code or is this something you type in on the fly?
Just for completeness can I confirm this same SIP address is working fine with the sample application?
And confirm you are developing a web browser application?
Cheers,
Rach
04-13-2017 07:37 AM
Hi, Rach. I can gather a full set of logs and more complete code snippet, but something you said seemed curious to me and wanted to clarify first.
When I ask for the remotePartyDisplayName what I would expect to get back would be the value set by my remote SIP server for the answering party ID. So just to reference that SIP message in my first post, I would expect to get the "CCX Queue" value from this SIP header in my web application:
I am setting this value in CUCM by assigning that value to the answering party "Display Name" field.
There are no problems with call setup or answer. When I call this SIP address from both my app and the sample app, they both work fine. I'm just not getting the value I expect when I call the getRemotePartyDisplayName function. I wonder if I misunderstand what I should expect to be returned from this function.
Let me know if we're on the same page and I'll gather a full set of logs and code.
04-17-2017 09:56 AM
Hi Bradley.
Sorry you're totally right, I've misunderstood your original question. So just to make sure we are on the same page now. CCX Queue is appearing as expected in the logs but it's not being represented on the front end where remotePartyDisplayName is being used, is that correct?
For this you are using:
But are returning an empty string when attempting this?
Cheers,
Rach D
04-17-2017 11:43 AM
Hey, Rach. You got it. In the above scenario, the onRemoteDisplayNameChanged callback is never even being triggered.
I've also attempted the following method for retrieving the remote display name, and when I do this it is returning an empty string.
call.onInCall = function () {
var remoteParty = call.getRemotePartyDisplayName();
I would hope to be getting "CCX Queue" returned.
04-17-2017 12:14 PM
Thanks for confirming Bradley.
I'm just going to confirm with our team here in the UK. Hopefully we will have something for you soon (it's been a bank holiday weekend here (fri and monday off) so may be a little lag in catching up
Will get back to you as soon as we have anything.
Cheers,
Rach D
