share projects on forum
Dfahlenkamp1
Is there a section on this forum where we can upload and share our projects?
I have written a little windows based app which can connect to a Cisco endpoint and perform various tasks remotely which can not be done from the web interface.
It also has a function that draws a packet loss graph dynamically and writes all data to a SQL compact database which can then be exported to Excel.
The app has been tested on C-series and SX-series endpoints on software version TC7.1.4
I would like to share this for testing as well as it might help other forum members with their projects.
I have updated the post and attached the msi file.
feel free to download and test the app, let me know what error you get should you get any.
You need to install SQL server compact edition 3.5 for the app to work.
I have updated the app to now supports software version TC7.3.0
Message was edited by: Denis Fahlenkamp
npetrele
Hi Denis,
If a zipped up file isn't too large, you should be able to attach it to a forum post. Click on "Use advanced editor" above the post you're editing, and you should see the option at the bottom of your post.
npetrele
Hi Denis,
