What ports does the Cisco Web Communicator add-on uses to communicate with CUCM server?
abhiisheek
We are working on integrating CUCM using Jabber SDK. I wanted to know what all ports the Cisco web communicator add-on uses to communicate with the CUCM server?
Also it would be more helpful, if you point me Cisco Web Communicator documentation.
Abhishek
jocreed
there are many ports that it would be connected to on the CUCM side.  the media port would be randomized so there is not a specific static port to know where to connect.  However there will be some static ports like SIP, HTTP and LDAP.
The following link is a good guide to use for port usage by CUCM (TCP and UDP Port Usage Guide for Cisco Unified Communications Manager, Release 10.0(1) - Cisco Unified Communications M…)
Hope that is useful to you.
