APIC-EM Zero Touch Deployment API manual
Hi all,
how can I access the Zero Touch Deployment API manual under
APIC EM Reference.
Every time I try to access, I get the message
"Can't read from server. It may not have the appropriate access-control-origin settings."
Thanks in advance!
Christian Heußen
Geevarghese Cheria
Hi Christian,
   This could be because the  Zero Touch Deployment application has not been enabled for the release of the documentation which you are browsing. Will update you soon after checking with the team.
Thanks and Regards,
Geevarghese
