Compatible APIC versions?
tigephillips
Level 2
Level 2
Is there a list of compatible APIC versions?  I upgraded to apic-1.0(2j) today and the standard session login fails now.  I also cloned the latest version and tried the tests.  They produced 10 errors.  Shown below.
Code:
    session = ACI.Session(url, login, password)
    response = session.login()
Produces the following when executing session.login():
Traceback (most recent call last):
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk/Tkinter.py", line 1470, in __call__
    return self.func(*args)
  File "./gui_test_9.py", line 149, in login
  File "build/bdist.macosx-10.9-intel/egg/acitoolkit/acisession.py", line 227, in login
    resp = self._send_login()
  File "build/bdist.macosx-10.9-intel/egg/acitoolkit/acisession.py", line 207, in _send_login
    ret = self.session.post(login_url, data=jcred, verify=self.verify_ssl)
  File "/Library/Python/2.7/site-packages/requests-1.2.3-py2.7.egg/requests/sessions.py", line 377, in post
    return self.request('POST', url, data=data, **kwargs)
  File "/Library/Python/2.7/site-packages/requests-1.2.3-py2.7.egg/requests/sessions.py", line 335, in request
    resp = self.send(prep, **send_kwargs)
  File "/Library/Python/2.7/site-packages/requests-1.2.3-py2.7.egg/requests/sessions.py", line 438, in send
    r = adapter.send(request, **kwargs)
  File "/Library/Python/2.7/site-packages/requests-1.2.3-py2.7.egg/requests/adapters.py", line 327, in send
    raise ConnectionError(e)
ConnectionError: HTTPSConnectionPool(host='10.93.130.125', port=443): Max retries exceeded with url: //api/aaaLogin.json (Caused by <class 'socket.error'>: [Errno 54] Connection reset by peer)
(I'm only included the first error)
Command:  python aciphysobject_test.py
.....E...EEEEEEEEE....................
ERROR: test_find (__main__.TestFind)
  File "aciphysobject_test.py", line 628, in test_find
    self.assertIn(interface2, results)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/unittest/case.py", line 802, in assertIn
    if member not in container:
  File "build/bdist.macosx-10.9-intel/egg/acitoolkit/acitoolkit.py", line 1647, in __eq__
    if (self.interface_type == other.interface_type and
AttributeError: 'Node' object has no attribute 'interface_type'
Zach Seils
Level 11
Level 11
I suspect this is due to bug CSCur62241. The APIC web server no longer accepts SSL3.0/TLS1.0 connections, which causes you to get errors like you’ve described. You can install python on OS X using homebrew and compile it against openssl 1.0.1* to get TLS1.1 and TLS1.2.
Alternatively, you can temporarily force all APIC communication to be via HTTP instead of HTTPS, so your script can execute successfully. To do this:
- On the menu bar, FABRIC -> Fabric Policies -> Pod Policies -> Policies -> Communication
- Under Communication, click the default policy
- In the Work pane, enable HTTP and disable HTTPS
Zach
6 Replies 6
Zach Seils
Level 11
Level 11
Zach
Thanks Zach! I'll give it a go.
-Tige
Zach,
Looks like I fixed the SSL issue, but now it looks like the websocket library is having an issue.. To test things I used an old script I wrote that uses 'requests' rather than websocket. You can see below that the requests module still works after the upgrade, but the websocket fails with both SSL and HTTP.
Thanks for any help. I can send the scripts if requested.
-Tige
TIPHILLI-M-20VC:cisco_aci tigelane$ ./aci_login-requests.py
About to use Requests
URL: https://10.93.130.125/api/aaaLogin.json?gui-token-request=yes
User: apiuser
Press Enter to continue or "q" to exit
Login completed. We're done!
TIPHILLI-M-20VC:cisco_aci tigelane$ ./aci_login-websocket.py
About to use native aci toolkit
URL: https://10.93.130.125:443/
User: apiuser
About to execute: response = session.login()
File "./aci_login-websocket.py", line 83, in
main()
File "./aci_login-websocket.py", line 79, in main
create_login()
File "./aci_login-websocket.py", line 58, in create_login
File "build/bdist.macosx-10.9-intel/egg/acitoolkit/acisession.py", line 211, in sendlogin
File "build/bdist.macosx-10.9-intel/egg/acitoolkit/acisession.py", line 99, in openweb_socket
File "/usr/local/lib/python2.7/site-packages/websocket/_core.py", line 266, in create_connection
websock.connect(url, **options)
File "/usr/local/lib/python2.7/site-packages/websocket/_core.py", line 524, in connect
self._handshake(hostname, port, resource, **options)
File "/usr/local/lib/python2.7/site-packages/websocket/_core.py", line 596, in _handshake
resp_headers = self._get_resp_headers()
File "/usr/local/lib/python2.7/site-packages/websocket/_core.py", line 549, in getresp_headers
raise WebSocketException("Handshake status %d" % status)
websocket._exceptions.WebSocketException: Handshake status 404
Tige Phillips - Vertical Solutions Architect - US Public Sector: SLED Western Operation
Audio: 408.894.3312 - Email & Video & IM: tiphilli@cisco.com<mailto:tiphilli@cisco.com> - Cisco Systems
Proudly “Serving those who Protect, Serve and Educate"
Hi Tige,
Try editing credentials.py - remove trailing '/' or ':80/'
Example:
From
URL = 'http://' + IPADDR + ':80/'
To
URL = 'https://' + IPADDR
and try again.
Kind regards,
Mio
Yep, that fixed it. This is the default setup on github. Should probably be changed if it's a real issue and not something I've done somewhere else in the python module.
Thank you Mio!
-Tige
Tige Phillips
408.894.3312
Glad to hear that!
Thanks for bringing this up, we'll fix it on github.
Kind regards,
Mio
