Devices in UNKNOWN state
John Capobianco
Hello -
I currently have 6 devices in an UNKNOWN state; they discovery fine with CLI / SSH / SNMP access all passing; I can SSH to the devices directly from APIC-EM. I have tried multiple discoveries; deleted the devices; re-added the devices. However I can not get them into a fully Managed state.
One of the devices is my 6500 Core so things like Pathtrace across the Core fail
1 - 6513E - 15.2(1)SY3
3 - 4500-X - 03.06.06.E
2 - Nexus 5k - 7.1(4)N1(1)
The 6500 is in a VS40 (VSS with 4 supervisors) and my 4500-X are all VSS
This is my lab environment we are hoping to move to a production instance soon however until I can fully manage all of my devices in my lab environment I am holding off on my production deployment. I have an open TAC / have been working with TAC but have not found the root cause.
Do I need to hold off for version 2.0? Is there a release for 2.0 scheduled?
Any assistance would be greatly appreciated
13 Replies 13
aradford
What version of APIC-EM are you running?
I am running 1.5.0.1368
Username / password and SNMP is all fine during Discovery everything passes (CLI / SNMP / SSH)
1. Can you share the discovery log?
     ssh grapevine@<cluster-ip>
     grape instance status | grep inventory (the output would list the <ip-address> of the inventory manager-service
     ssh grapevine@<ip-address>
     less /var/log/grapevine/services/apic-em-inventory-manager-service/[version-number]/apic-em-inventory-manager-service.log
2. Can you share the output of "snmpwalk -v2c -c <community> <device-ip> 1.3.6.1.2.1"
3. Any https/netconf validations?
Attached are the requested outputs
I am not sure about https/netconf validations what do you require?
Thanks for attaching the logs.
Can you please check if the "apic-em-inventory-manager-service" service is running?
Command:
grape instance status | grep apic-em-inventory-manager-service
Example for a proper output:
apic-em-inventory-manager-service    5.1.31.1368  running      3d4390a6-c6d3-4a23-a9d6-e7d605a00aa0  169.254.0.77    14 days, 13:15:10
apic-em-inventory-manager-service    5.1.31.1368  running      1c070547-699f-4256-a468-f7f5712ca7a7  169.254.0.209   29 days, 2:52:31
How about enable password?
Could you send the screenshot of discovery and error?
Parthiv
Everything passes / is successful on my discovery jobs
See attachments / screenshots for the UNKNOWN
The Help icon suggests to re-run discovery (which always passes) or contact TAC (which I have)
TAC has tried to use the database editor to manually discovery / delete / add the device 172.24.128.1 but we can never get it out of the UNKNOWN state
Also as noted this is the 6500 Core - if I cannot manage the Core things like Pathtrace result in errors
Thanks for your time
Can you please send the output of "grape instance status"?
Also, i do see strange printouts at the end of the "apic-em-inventory-manager-service" log file
(e.g. Full thread dump, [1]+  Stopped                 less /var/log/grapevine/services/apic-em-inventory-manager-service/5.1.31.1368/apic-em-inventory-manager-service.log)
I'll try to check that..
Thanks!
SERVICE                              VERSION      STATE        CLIENT                                IP              UPTIME
access-policy-programmer-service     5.1.31.1368  running      5b7c0ebe-a304-4dc3-89c3-602166d32a81  169.254.0.104   29 days, 4:13:25
apic-em-event-service                5.1.31.1368  running      d02c168d-5d8a-4e77-babd-e1ef6ae8e198  169.254.0.218   29 days, 4:11:56
apic-em-inventory-manager-service    5.1.31.1368  running      1c070547-699f-4256-a468-f7f5712ca7a7  169.254.0.209   29 days, 4:07:27
apic-em-jboss-ejbca                  5.1.31.1368  running      5821ae79-ee4e-465a-8688-aa80cae88bfb  169.254.0.22    29 days, 4:13:50
apic-em-network-programmer-service   5.1.31.1368  running      161a5d65-c96e-482f-a983-81b1c4b35bf9  169.254.0.200   29 days, 4:07:31
apic-em-network-programmer-service   5.1.31.1368  running      b55aca33-4fc6-4b3e-a5a9-0940395c2d59  169.254.0.14    29 days, 3:40:56
apic-em-pki-broker-service           1.5.0.1368   running      4ff82566-aa30-4a7b-b9ca-7d004c56b1aa  169.254.0.95    29 days, 4:14:33
app-vis-policy-programmer-service    1.4.1.504    running      5b7c0ebe-a304-4dc3-89c3-602166d32a81  169.254.0.104   29 days, 4:13:20
cas-service                          5.0.31.4021  running      d42d138c-45e8-4dc4-838c-240008325f33  169.254.0.196   29 days, 4:25:18
cassandra                            1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:15:13
election-service                     5.0.31.4021  running      161a5d65-c96e-482f-a983-81b1c4b35bf9  169.254.0.200   29 days, 4:23:58
file-service                         5.1.31.1368  running      161a5d65-c96e-482f-a983-81b1c4b35bf9  169.254.0.200   29 days, 4:16:38
grapevine                            1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:15:09
grapevine-coordinator-service        1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:15:00
grapevine-log-collector              1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:14:56
grouping-service                     5.1.31.1368  running      161a5d65-c96e-482f-a983-81b1c4b35bf9  169.254.0.200   29 days, 4:09:52
identity-manager-pxgrid-service      5.1.31.1368  running      bce49a8b-8555-4691-826c-b3c24e91c773  169.254.0.224   29 days, 4:11:27
integrity-verification-service       5.1.31.203   running      ed2c819f-9ddf-4d4c-a10f-13fe53db44a4  169.254.0.250   29 days, 4:17:54
ip-pool-manager-service              1.4.1.504    running      d42d138c-45e8-4dc4-838c-240008325f33  169.254.0.196   29 days, 4:17:41
ipgeo-service                        1.4.1.504    running      161a5d65-c96e-482f-a983-81b1c4b35bf9  169.254.0.200   29 days, 4:22:23
iwan-analytics-service               1.4          harvested    None                                  None
nbar-policy-programmer-service       5.1.31.1368  running      e999cab8-fc00-4d6e-ac24-baf59e86a570  169.254.0.241   29 days, 4:13:35
network-poller-service               5.1.31.1368  running      6a2c1648-be91-4ad3-9e2f-0e75b2f0bea8  169.254.0.205   29 days, 4:08:55
node-ui                              1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:15:05
pfr-policy-programmer-service        1.4.1.504    running      97ec6075-61dc-491c-b0ea-023fbe34c3e8  169.254.0.49    29 days, 4:16:21
pnp-service                          5.17.31.211  running      4ff82566-aa30-4a7b-b9ca-7d004c56b1aa  169.254.0.95    29 days, 4:14:27
policy-analysis-service              5.1.31.1368  running      bce49a8b-8555-4691-826c-b3c24e91c773  169.254.0.224   29 days, 4:11:27
policy-manager-service               5.1.31.1368  running      bce49a8b-8555-4691-826c-b3c24e91c773  169.254.0.224   29 days, 4:12:02
postgres                             5.1.31.1368  running      5902e42e-f79a-4af8-9b03-ca22cca9e898  169.254.0.111   29 days, 4:21:47
qos-lan-policy-programmer-service    5.1.31.1368  running      ed2c819f-9ddf-4d4c-a10f-13fe53db44a4  169.254.0.250   29 days, 4:12:26
qos-monitoring-service               5.1.31.1368  running      d42d138c-45e8-4dc4-838c-240008325f33  169.254.0.196   29 days, 4:16:33
qos-policy-programmer-service        5.1.31.1368  running      e999cab8-fc00-4d6e-ac24-baf59e86a570  169.254.0.241   29 days, 4:13:30
rabbitmq                             1.0.0        running      b0430126-678b-4404-a52c-50de06d6a742  169.254.0.1     41 days, 2:15:18
rbac-service                         5.0.31.4021  running      d42d138c-45e8-4dc4-838c-240008325f33  169.254.0.196   29 days, 4:25:23
reverse-proxy                        5.0.31.4021  running      da9a8a53-2c15-45d5-b9b0-f2d06e625b34  169.254.0.1     29 days, 4:26:58
router                               5.0.31.4021  running      da9a8a53-2c15-45d5-b9b0-f2d06e625b34  169.254.0.1     29 days, 4:27:04
scheduler-service                    5.1.31.1368  running      942ae612-5e21-4f03-b3a6-9a114df9e4cd  169.254.0.228   29 days, 4:16:17
task-service                         5.1.31.1368  running      942ae612-5e21-4f03-b3a6-9a114df9e4cd  169.254.0.228   29 days, 4:16:26
telemetry-service                    5.1.31.1368  running      942ae612-5e21-4f03-b3a6-9a114df9e4cd  169.254.0.228   29 days, 4:16:26
topology-service                     1.5.0.1368   running      bce49a8b-8555-4691-826c-b3c24e91c773  169.254.0.224   29 days, 4:11:23
visibility-service                   1.4.1.504    running      97ec6075-61dc-491c-b0ea-023fbe34c3e8  169.254.0.49    29 days, 4:14:07
When we (TAC) check the inventory logs we found the following - hope this helps
inventory.log:[2017-09-11 13:54:22,888] [XDE ThreadPool 18] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10838221 in time 814 hook time 128  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 13:54:22,888] [XDE ThreadPool 18] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 13:54:22,888] [ICE Service - Network 11] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 13:54:22,888] [ICE Service - Network 11] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 13:54:33,221] [XDE ThreadPool 10] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 14:19:39,335] [XDE ThreadPool 6] [inventory] [ERROR] - Exception executing function [com.cisco.ef.config.xde.lisp7k-inventory]procedure runId 10842227 in time 3 hook time 0  deviceId: 824834; CredentialId: 824834; ManagementIP: 172.24.170.16
inventory.log-[2017-09-11 14:19:39,335] [XDE ThreadPool 6] [inventory] [ERROR] - Exception Stack: com.cisco.nm.pal.client.PALException: <palError><deviceId>824834</deviceId><code>NO_PAL_RULE</code><message>No rule test for function "[com.cisco.ef.config.xde.lisp7k-inventory]lisp7k-inventory.xpa/xmp-im-lisp-module/xmp-im-lisp-module.par" matched for device "824834". For a rule test to succeed, every test variable/value in the rule must be set on the device. Either this device is not recognized by your inventory provider or the set of attributes for the device does not match any rule test in the action. </message><credential name="software">NX-OS</credential><credential name="DEVICE_NAME">824834</credential><credential name="DEVICE_ID">824834</credential></palError>
inventory.log:[2017-09-11 14:19:50,725] [XDE ThreadPool 26] [inventory] [ERROR] - Exception occured while converting the output of workflow runId 10842279 deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:19:50,726] [XDE ThreadPool 26] [inventory] [ERROR] - Exception Stack: com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessHookException: java.lang.reflect.InvocationTargetException::sun.reflect.GeneratedMethodAccessor342.invoke(Unknown Source)::sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)::java.lang.reflect.Method.invoke(Method.java:606)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager._postProcessModelObject(BusinessProcessManager.java:119)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager.postProcessModelObjectWithResponse(BusinessProcessManager.java:146)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:296)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:306)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.parseObjectsFromXML(PalXMLToPOJOConvertor.java:190)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.featureHook(CollectorFeatureHookTask.java:53)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.externalFunctionCall(CollectorFeatureHookTask.java:113)::com.cisco.nm.expression.function.system.system.AbstractExternalFunction.callAsync(AbstractExternalFunction.java:86)::com.cisco.nm.expression.function.system.system.HookFunction.callAsync(HookFunction.java:53)::com.cisco.nm.expression.function.FunctionRunnerContext.runFunction(FunctionRunnerContext.java:97)::com.cisco.nm.expression.function.FunctionRunner.runFunctionAsync(FunctionRunner.java:65)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.call(JavaScriptXdeFunctionObject.java:56)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.access$300(JavaScriptXdeFunctionObject.java:40)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject.call(JavaScriptXdeFunctionObject.java:193)::org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1482)::org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)::org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)::org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)::org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3096)::org.mozilla.javascript.Context.callFunctionWithContinuations(Context.java:1172)::org.mozilla.javascript.Context.executeScriptWithContinuations(Context.java:1139)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:213)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.JavaScriptStep.run(JavaScriptStep.java:46)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.JavaScriptStep$1.executeExpressionResult(JavaScriptStep.java:53)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.futureCallback(JavaScriptCompiler.java:254)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.functionResult(JavaScriptXdeFunctionObject.java:89)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.expression.function.xep.XepBindingCallingContextRunAsRules.functionResult(XepBindingCallingContextRunAsRules.java:75)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.pal.function.par.ParFileFunctionContext.workflowFinished(ParFileFunctionContext.java:109)::com.cisco.nm.workflow.run.WorkflowRunner.runFlowResult(WorkflowRunner.java:72)::com.cisco.nm.workflow.run.FlowStepContainerRunner.finishedLoopWithSuccess(FlowStepContainerRunner.java:196)::com.cisco.nm.util.async.AsyncWhileLoop.haltLoopWithSuccess(AsyncWhileLoop.java:68)::com.cisco.nm.workflow.run.FlowStepContainerRunner.flowFinishedWithResult(FlowStepContainerRunner.java:208)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:142)::com.cisco.nm.workflow.steps.ReturnStep$1.executeExpressionResult(ReturnStep.java:56)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:224)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.ReturnStep.run(ReturnStep.java:49)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.HandlerStep$HandlerStepImpl.handlerResult(HandlerStep.java:157)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.run(HandlerCallbackWrapped.java:102)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.makeCallback(HandlerCallbackWrapped.java:90)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.handlerResult(HandlerCallbackWrapped.java:62)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.finishedIterationWithSuccess(CLIHandlerImplBaseShowDocument.java:74)::com.cisco.nm.util.async.AsyncIterator.haltIterationWithSuccess(AsyncIterator.java:87)::com.cisco.nm.util.async.AsyncIterator.processLoopInternal(AsyncIterator.java:39)::com.cisco.nm.util.async.AsyncIterator.continueIteration(AsyncIterator.java:72)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.sessionRunnerCallbackResult(CLIHandlerImplBaseShowDocument.java:151)::com.cisco.xmp.utilities.sessionrunner.XMPCustomSessionRunner$XMPCacheCLIHandlerCallback.sessionRunnerCallbackResult(XMPCustomSessionRunner.java:79)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:305)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionStopSuccess(SessionRunnerWorker.java:236)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopSuccess(CliSessionContextBase.java:96)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopSuccess(CliTransportCommunicator.java:227)::com.cisco.nm.pal.cli.transport.ssh2.CliTransportProviderAsyncSSH2.stop(CliTransportProviderAsyncSSH2.java:258)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopAsync(CliTransportCommunicator.java:112)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopAsync(CliSessionContextBase.java:91)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveSession.stopAsync(CliInteractiveSession.java:35)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:275)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionRunCommandSuccess(SessionRunnerWorker.java:199)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveShowCommandRunner.runInteractiveCommandsAsyncSuccess(CliInteractiveShowCommandRunner.java:80)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.succeeded(CliInteractiveCommandRunner.java:281)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.responseReceived(CliInteractiveCommandRunner.java:219)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.access$000(CliInteractiveCommandRunner.java:23)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner$MainCommandCallback.expectResult(CliInteractiveCommandRunner.java:30)::com.cisco.nm.pal.cli.transport.CliTransportCommunicatorExpectEngine$1.run(CliTransportCommunicatorExpectEngine.java:151)::java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)::java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)::com.cisco.nm.run.threadpool.ThreadPool$PooledThread.run(ThreadPool.java:60)
inventory.log:[2017-09-11 14:19:50,726] [XDE ThreadPool 26] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10842279 in time 1922 hook time 133  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:19:50,727] [XDE ThreadPool 26] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 14:19:50,727] [ICE Service - Network 11] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:19:50,727] [ICE Service - Network 11] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 14:19:57,937] [XDE ThreadPool 15] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 14:45:12,542] [XDE ThreadPool 19] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 14:45:15,179] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 14:45:15,179] [XDE ThreadPool 21] [inventory] [ERROR] - Exception occured while converting the output of workflow runId 10846309 deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:45:15,180] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessHookException: java.lang.reflect.InvocationTargetException::sun.reflect.GeneratedMethodAccessor342.invoke(Unknown Source)::sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)::java.lang.reflect.Method.invoke(Method.java:606)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager._postProcessModelObject(BusinessProcessManager.java:119)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager.postProcessModelObjectWithResponse(BusinessProcessManager.java:146)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:296)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:306)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.parseObjectsFromXML(PalXMLToPOJOConvertor.java:190)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.featureHook(CollectorFeatureHookTask.java:53)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.externalFunctionCall(CollectorFeatureHookTask.java:113)::com.cisco.nm.expression.function.system.system.AbstractExternalFunction.callAsync(AbstractExternalFunction.java:86)::com.cisco.nm.expression.function.system.system.HookFunction.callAsync(HookFunction.java:53)::com.cisco.nm.expression.function.FunctionRunnerContext.runFunction(FunctionRunnerContext.java:97)::com.cisco.nm.expression.function.FunctionRunner.runFunctionAsync(FunctionRunner.java:65)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.call(JavaScriptXdeFunctionObject.java:56)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.access$300(JavaScriptXdeFunctionObject.java:40)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject.call(JavaScriptXdeFunctionObject.java:193)::org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1482)::org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)::org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)::org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)::org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3096)::org.mozilla.javascript.Context.callFunctionWithContinuations(Context.java:1172)::org.mozilla.javascript.Context.executeScriptWithContinuations(Context.java:1139)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:213)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.JavaScriptStep.run(JavaScriptStep.java:46)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.JavaScriptStep$1.executeExpressionResult(JavaScriptStep.java:53)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.futureCallback(JavaScriptCompiler.java:254)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.functionResult(JavaScriptXdeFunctionObject.java:89)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.expression.function.xep.XepBindingCallingContextRunAsRules.functionResult(XepBindingCallingContextRunAsRules.java:75)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.pal.function.par.ParFileFunctionContext.workflowFinished(ParFileFunctionContext.java:109)::com.cisco.nm.workflow.run.WorkflowRunner.runFlowResult(WorkflowRunner.java:72)::com.cisco.nm.workflow.run.FlowStepContainerRunner.finishedLoopWithSuccess(FlowStepContainerRunner.java:196)::com.cisco.nm.util.async.AsyncWhileLoop.haltLoopWithSuccess(AsyncWhileLoop.java:68)::com.cisco.nm.workflow.run.FlowStepContainerRunner.flowFinishedWithResult(FlowStepContainerRunner.java:208)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:142)::com.cisco.nm.workflow.steps.ReturnStep$1.executeExpressionResult(ReturnStep.java:56)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:224)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.ReturnStep.run(ReturnStep.java:49)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.HandlerStep$HandlerStepImpl.handlerResult(HandlerStep.java:157)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.run(HandlerCallbackWrapped.java:102)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.makeCallback(HandlerCallbackWrapped.java:90)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.handlerResult(HandlerCallbackWrapped.java:62)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.finishedIterationWithSuccess(CLIHandlerImplBaseShowDocument.java:74)::com.cisco.nm.util.async.AsyncIterator.haltIterationWithSuccess(AsyncIterator.java:87)::com.cisco.nm.util.async.AsyncIterator.processLoopInternal(AsyncIterator.java:39)::com.cisco.nm.util.async.AsyncIterator.continueIteration(AsyncIterator.java:72)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.sessionRunnerCallbackResult(CLIHandlerImplBaseShowDocument.java:151)::com.cisco.xmp.utilities.sessionrunner.XMPCustomSessionRunner$XMPCacheCLIHandlerCallback.sessionRunnerCallbackResult(XMPCustomSessionRunner.java:79)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:305)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionStopSuccess(SessionRunnerWorker.java:236)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopSuccess(CliSessionContextBase.java:96)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopSuccess(CliTransportCommunicator.java:227)::com.cisco.nm.pal.cli.transport.ssh2.CliTransportProviderAsyncSSH2.stop(CliTransportProviderAsyncSSH2.java:258)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopAsync(CliTransportCommunicator.java:112)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopAsync(CliSessionContextBase.java:91)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveSession.stopAsync(CliInteractiveSession.java:35)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:275)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionRunCommandSuccess(SessionRunnerWorker.java:199)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveShowCommandRunner.runInteractiveCommandsAsyncSuccess(CliInteractiveShowCommandRunner.java:80)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.succeeded(CliInteractiveCommandRunner.java:281)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.responseReceived(CliInteractiveCommandRunner.java:219)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.access$000(CliInteractiveCommandRunner.java:23)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner$MainCommandCallback.expectResult(CliInteractiveCommandRunner.java:30)::com.cisco.nm.pal.cli.transport.CliTransportCommunicatorExpectEngine$1.run(CliTransportCommunicatorExpectEngine.java:151)::java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)::java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)::com.cisco.nm.run.threadpool.ThreadPool$PooledThread.run(ThreadPool.java:60)
inventory.log:[2017-09-11 14:45:15,181] [XDE ThreadPool 21] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10846309 in time 831 hook time 131  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:45:15,181] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 14:45:15,181] [ICE Service - Network 9] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 14:45:15,182] [ICE Service - Network 9] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 14:45:21,982] [XDE ThreadPool 7] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 14:46:11,741] [XDE ThreadPool 13] [inventory] [ERROR] - Exception executing function [com.cisco.ef.config.xde.lisp7k-inventory]procedure runId 10846387 in time 2 hook time 0  deviceId: 824834; CredentialId: 824834; ManagementIP: 172.24.170.16
inventory.log-[2017-09-11 14:46:11,742] [XDE ThreadPool 13] [inventory] [ERROR] - Exception Stack: com.cisco.nm.pal.client.PALException: <palError><deviceId>824834</deviceId><code>NO_PAL_RULE</code><message>No rule test for function "[com.cisco.ef.config.xde.lisp7k-inventory]lisp7k-inventory.xpa/xmp-im-lisp-module/xmp-im-lisp-module.par" matched for device "824834". For a rule test to succeed, every test variable/value in the rule must be set on the device. Either this device is not recognized by your inventory provider or the set of attributes for the device does not match any rule test in the action. </message><credential name="software">NX-OS</credential><credential name="DEVICE_NAME">824834</credential><credential name="DEVICE_ID">824834</credential></palError>
inventory.log-[2017-09-11 15:10:41,273] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 15:10:41,273] [XDE ThreadPool 21] [inventory] [ERROR] - Exception occured while converting the output of workflow runId 10850105 deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:10:41,275] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessHookException: java.lang.reflect.InvocationTargetException::sun.reflect.GeneratedMethodAccessor342.invoke(Unknown Source)::sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)::java.lang.reflect.Method.invoke(Method.java:606)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager._postProcessModelObject(BusinessProcessManager.java:119)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager.postProcessModelObjectWithResponse(BusinessProcessManager.java:146)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:296)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:306)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.parseObjectsFromXML(PalXMLToPOJOConvertor.java:190)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.featureHook(CollectorFeatureHookTask.java:53)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.externalFunctionCall(CollectorFeatureHookTask.java:113)::com.cisco.nm.expression.function.system.system.AbstractExternalFunction.callAsync(AbstractExternalFunction.java:86)::com.cisco.nm.expression.function.system.system.HookFunction.callAsync(HookFunction.java:53)::com.cisco.nm.expression.function.FunctionRunnerContext.runFunction(FunctionRunnerContext.java:97)::com.cisco.nm.expression.function.FunctionRunner.runFunctionAsync(FunctionRunner.java:65)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.call(JavaScriptXdeFunctionObject.java:56)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.access$300(JavaScriptXdeFunctionObject.java:40)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject.call(JavaScriptXdeFunctionObject.java:193)::org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1482)::org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)::org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)::org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)::org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3096)::org.mozilla.javascript.Context.callFunctionWithContinuations(Context.java:1172)::org.mozilla.javascript.Context.executeScriptWithContinuations(Context.java:1139)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:213)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.JavaScriptStep.run(JavaScriptStep.java:46)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.JavaScriptStep$1.executeExpressionResult(JavaScriptStep.java:53)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.futureCallback(JavaScriptCompiler.java:254)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.functionResult(JavaScriptXdeFunctionObject.java:89)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.expression.function.xep.XepBindingCallingContextRunAsRules.functionResult(XepBindingCallingContextRunAsRules.java:75)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.pal.function.par.ParFileFunctionContext.workflowFinished(ParFileFunctionContext.java:109)::com.cisco.nm.workflow.run.WorkflowRunner.runFlowResult(WorkflowRunner.java:72)::com.cisco.nm.workflow.run.FlowStepContainerRunner.finishedLoopWithSuccess(FlowStepContainerRunner.java:196)::com.cisco.nm.util.async.AsyncWhileLoop.haltLoopWithSuccess(AsyncWhileLoop.java:68)::com.cisco.nm.workflow.run.FlowStepContainerRunner.flowFinishedWithResult(FlowStepContainerRunner.java:208)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:142)::com.cisco.nm.workflow.steps.ReturnStep$1.executeExpressionResult(ReturnStep.java:56)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:224)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.ReturnStep.run(ReturnStep.java:49)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.HandlerStep$HandlerStepImpl.handlerResult(HandlerStep.java:157)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.run(HandlerCallbackWrapped.java:102)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.makeCallback(HandlerCallbackWrapped.java:90)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.handlerResult(HandlerCallbackWrapped.java:62)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.finishedIterationWithSuccess(CLIHandlerImplBaseShowDocument.java:74)::com.cisco.nm.util.async.AsyncIterator.haltIterationWithSuccess(AsyncIterator.java:87)::com.cisco.nm.util.async.AsyncIterator.processLoopInternal(AsyncIterator.java:39)::com.cisco.nm.util.async.AsyncIterator.continueIteration(AsyncIterator.java:72)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.sessionRunnerCallbackResult(CLIHandlerImplBaseShowDocument.java:151)::com.cisco.xmp.utilities.sessionrunner.XMPCustomSessionRunner$XMPCacheCLIHandlerCallback.sessionRunnerCallbackResult(XMPCustomSessionRunner.java:79)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:305)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionStopSuccess(SessionRunnerWorker.java:236)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopSuccess(CliSessionContextBase.java:96)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopSuccess(CliTransportCommunicator.java:227)::com.cisco.nm.pal.cli.transport.ssh2.CliTransportProviderAsyncSSH2.stop(CliTransportProviderAsyncSSH2.java:258)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopAsync(CliTransportCommunicator.java:112)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopAsync(CliSessionContextBase.java:91)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveSession.stopAsync(CliInteractiveSession.java:35)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:275)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionRunCommandSuccess(SessionRunnerWorker.java:199)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveShowCommandRunner.runInteractiveCommandsAsyncSuccess(CliInteractiveShowCommandRunner.java:80)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.succeeded(CliInteractiveCommandRunner.java:281)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.responseReceived(CliInteractiveCommandRunner.java:219)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.access$000(CliInteractiveCommandRunner.java:23)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner$MainCommandCallback.expectResult(CliInteractiveCommandRunner.java:30)::com.cisco.nm.pal.cli.transport.CliTransportCommunicatorExpectEngine$1.run(CliTransportCommunicatorExpectEngine.java:151)::java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)::java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)::com.cisco.nm.run.threadpool.ThreadPool$PooledThread.run(ThreadPool.java:60)
inventory.log:[2017-09-11 15:10:41,275] [XDE ThreadPool 21] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10850105 in time 888 hook time 137  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:10:41,276] [XDE ThreadPool 21] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 15:10:41,276] [ICE Service - Network 8] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:10:41,276] [ICE Service - Network 8] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 15:10:43,815] [XDE ThreadPool 20] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 15:10:47,966] [XDE ThreadPool 26] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 15:10:52,539] [XDE ThreadPool 9] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 15:10:53,413] [XDE ThreadPool 21] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log:[2017-09-11 15:36:05,784] [XDE ThreadPool 5] [inventory] [ERROR] - Exception occured while converting the output of workflow runId 10854081 deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:36:05,785] [XDE ThreadPool 5] [inventory] [ERROR] - Exception Stack: com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessHookException: java.lang.reflect.InvocationTargetException::sun.reflect.GeneratedMethodAccessor342.invoke(Unknown Source)::sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)::java.lang.reflect.Method.invoke(Method.java:606)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager._postProcessModelObject(BusinessProcessManager.java:119)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager.postProcessModelObjectWithResponse(BusinessProcessManager.java:146)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:296)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:306)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.parseObjectsFromXML(PalXMLToPOJOConvertor.java:190)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.featureHook(CollectorFeatureHookTask.java:53)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.externalFunctionCall(CollectorFeatureHookTask.java:113)::com.cisco.nm.expression.function.system.system.AbstractExternalFunction.callAsync(AbstractExternalFunction.java:86)::com.cisco.nm.expression.function.system.system.HookFunction.callAsync(HookFunction.java:53)::com.cisco.nm.expression.function.FunctionRunnerContext.runFunction(FunctionRunnerContext.java:97)::com.cisco.nm.expression.function.FunctionRunner.runFunctionAsync(FunctionRunner.java:65)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.call(JavaScriptXdeFunctionObject.java:56)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.access$300(JavaScriptXdeFunctionObject.java:40)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject.call(JavaScriptXdeFunctionObject.java:193)::org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1482)::org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)::org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)::org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)::org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3096)::org.mozilla.javascript.Context.callFunctionWithContinuations(Context.java:1172)::org.mozilla.javascript.Context.executeScriptWithContinuations(Context.java:1139)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:213)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.JavaScriptStep.run(JavaScriptStep.java:46)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.JavaScriptStep$1.executeExpressionResult(JavaScriptStep.java:53)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.futureCallback(JavaScriptCompiler.java:254)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.functionResult(JavaScriptXdeFunctionObject.java:89)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.expression.function.xep.XepBindingCallingContextRunAsRules.functionResult(XepBindingCallingContextRunAsRules.java:75)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.pal.function.par.ParFileFunctionContext.workflowFinished(ParFileFunctionContext.java:109)::com.cisco.nm.workflow.run.WorkflowRunner.runFlowResult(WorkflowRunner.java:72)::com.cisco.nm.workflow.run.FlowStepContainerRunner.finishedLoopWithSuccess(FlowStepContainerRunner.java:196)::com.cisco.nm.util.async.AsyncWhileLoop.haltLoopWithSuccess(AsyncWhileLoop.java:68)::com.cisco.nm.workflow.run.FlowStepContainerRunner.flowFinishedWithResult(FlowStepContainerRunner.java:208)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:142)::com.cisco.nm.workflow.steps.ReturnStep$1.executeExpressionResult(ReturnStep.java:56)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:224)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.ReturnStep.run(ReturnStep.java:49)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.HandlerStep$HandlerStepImpl.handlerResult(HandlerStep.java:157)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.run(HandlerCallbackWrapped.java:102)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.makeCallback(HandlerCallbackWrapped.java:90)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.handlerResult(HandlerCallbackWrapped.java:62)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.finishedIterationWithSuccess(CLIHandlerImplBaseShowDocument.java:74)::com.cisco.nm.util.async.AsyncIterator.haltIterationWithSuccess(AsyncIterator.java:87)::com.cisco.nm.util.async.AsyncIterator.processLoopInternal(AsyncIterator.java:39)::com.cisco.nm.util.async.AsyncIterator.continueIteration(AsyncIterator.java:72)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.sessionRunnerCallbackResult(CLIHandlerImplBaseShowDocument.java:151)::com.cisco.xmp.utilities.sessionrunner.XMPCustomSessionRunner$XMPCacheCLIHandlerCallback.sessionRunnerCallbackResult(XMPCustomSessionRunner.java:79)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:305)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionStopSuccess(SessionRunnerWorker.java:236)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopSuccess(CliSessionContextBase.java:96)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopSuccess(CliTransportCommunicator.java:227)::com.cisco.nm.pal.cli.transport.ssh2.CliTransportProviderAsyncSSH2.stop(CliTransportProviderAsyncSSH2.java:258)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopAsync(CliTransportCommunicator.java:112)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopAsync(CliSessionContextBase.java:91)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveSession.stopAsync(CliInteractiveSession.java:35)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:275)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionRunCommandSuccess(SessionRunnerWorker.java:199)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveShowCommandRunner.runInteractiveCommandsAsyncSuccess(CliInteractiveShowCommandRunner.java:80)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.succeeded(CliInteractiveCommandRunner.java:281)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.responseReceived(CliInteractiveCommandRunner.java:219)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.access$000(CliInteractiveCommandRunner.java:23)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner$MainCommandCallback.expectResult(CliInteractiveCommandRunner.java:30)::com.cisco.nm.pal.cli.transport.CliTransportCommunicatorExpectEngine$1.run(CliTransportCommunicatorExpectEngine.java:151)::java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)::java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)::com.cisco.nm.run.threadpool.ThreadPool$PooledThread.run(ThreadPool.java:60)
inventory.log:[2017-09-11 15:36:05,786] [XDE ThreadPool 5] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10854081 in time 822 hook time 163  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:36:05,786] [XDE ThreadPool 5] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 15:36:05,786] [ICE Service - Network 0] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 15:36:05,787] [ICE Service - Network 0] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 15:36:12,962] [XDE ThreadPool 1] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
inventory.log-[2017-09-11 16:01:30,286] [XDE ThreadPool 10] [inventory] [ERROR] - Exception Stack: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 16:01:30,286] [XDE ThreadPool 10] [inventory] [ERROR] - Exception occured while converting the output of workflow runId 10858579 deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 16:01:30,287] [XDE ThreadPool 10] [inventory] [ERROR] - Exception Stack: com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessHookException: java.lang.reflect.InvocationTargetException::sun.reflect.GeneratedMethodAccessor342.invoke(Unknown Source)::sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)::java.lang.reflect.Method.invoke(Method.java:606)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager._postProcessModelObject(BusinessProcessManager.java:119)::com.cisco.xmp.deviceaccess.businessProcessor.BusinessProcessManager.postProcessModelObjectWithResponse(BusinessProcessManager.java:146)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:296)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.getClassInfo(PalXMLToPOJOConvertor.java:306)::com.cisco.xmp.inventory.pojogen.PalXMLToPOJOConvertor.parseObjectsFromXML(PalXMLToPOJOConvertor.java:190)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.featureHook(CollectorFeatureHookTask.java:53)::com.cisco.xmp.inventory.ice.collectortask.CollectorFeatureHookTask.externalFunctionCall(CollectorFeatureHookTask.java:113)::com.cisco.nm.expression.function.system.system.AbstractExternalFunction.callAsync(AbstractExternalFunction.java:86)::com.cisco.nm.expression.function.system.system.HookFunction.callAsync(HookFunction.java:53)::com.cisco.nm.expression.function.FunctionRunnerContext.runFunction(FunctionRunnerContext.java:97)::com.cisco.nm.expression.function.FunctionRunner.runFunctionAsync(FunctionRunner.java:65)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.call(JavaScriptXdeFunctionObject.java:56)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.access$300(JavaScriptXdeFunctionObject.java:40)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject.call(JavaScriptXdeFunctionObject.java:193)::org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1482)::org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)::org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)::org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)::org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3096)::org.mozilla.javascript.Context.callFunctionWithContinuations(Context.java:1172)::org.mozilla.javascript.Context.executeScriptWithContinuations(Context.java:1139)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:213)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.JavaScriptStep.run(JavaScriptStep.java:46)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.JavaScriptStep$1.executeExpressionResult(JavaScriptStep.java:53)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.futureCallback(JavaScriptCompiler.java:254)::com.cisco.nm.expression.js.packageimport.JavaScriptXdeFunctionObject$JavaScriptXdeFunctionObjectContext.functionResult(JavaScriptXdeFunctionObject.java:89)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.expression.function.xep.XepBindingCallingContextRunAsRules.functionResult(XepBindingCallingContextRunAsRules.java:75)::com.cisco.nm.expression.function.FunctionRunnerContext.functionResult(FunctionRunnerContext.java:170)::com.cisco.nm.pal.function.par.ParFileFunctionContext.workflowFinished(ParFileFunctionContext.java:109)::com.cisco.nm.workflow.run.WorkflowRunner.runFlowResult(WorkflowRunner.java:72)::com.cisco.nm.workflow.run.FlowStepContainerRunner.finishedLoopWithSuccess(FlowStepContainerRunner.java:196)::com.cisco.nm.util.async.AsyncWhileLoop.haltLoopWithSuccess(AsyncWhileLoop.java:68)::com.cisco.nm.workflow.run.FlowStepContainerRunner.flowFinishedWithResult(FlowStepContainerRunner.java:208)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:142)::com.cisco.nm.workflow.steps.ReturnStep$1.executeExpressionResult(ReturnStep.java:56)::com.cisco.nm.workflow.steps.StepExpressionJavaScript$2.executeExpressionResult(StepExpressionJavaScript.java:121)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.callbackSuccess(JavaScriptCompiler.java:315)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.processResult(JavaScriptCompiler.java:305)::com.cisco.nm.expression.js.JavaScriptCompiler$JavaScriptExecutor.execute(JavaScriptCompiler.java:224)::com.cisco.nm.expression.js.JavaScriptCompiler.executeFunction(JavaScriptCompiler.java:155)::com.cisco.nm.expression.js.JavaScriptCompiler.executeExpression(JavaScriptCompiler.java:143)::com.cisco.nm.workflow.steps.StepExpressionJavaScript.executeExpression(StepExpressionJavaScript.java:118)::com.cisco.nm.workflow.steps.ReturnStep.run(ReturnStep.java:49)::com.cisco.nm.workflow.run.FlowStepContainerRunner.processLoop(FlowStepContainerRunner.java:106)::com.cisco.nm.util.async.AsyncWhileLoop.processLoopInternal(AsyncWhileLoop.java:35)::com.cisco.nm.util.async.AsyncWhileLoop.continueLoop(AsyncWhileLoop.java:53)::com.cisco.nm.workflow.run.FlowStepContainerRunner.runStepResult(FlowStepContainerRunner.java:132)::com.cisco.nm.workflow.steps.HandlerStep$HandlerStepImpl.handlerResult(HandlerStep.java:157)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.run(HandlerCallbackWrapped.java:102)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.makeCallback(HandlerCallbackWrapped.java:90)::com.cisco.nm.pal.handler.HandlerCallbackWrapped.handlerResult(HandlerCallbackWrapped.java:62)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.finishedIterationWithSuccess(CLIHandlerImplBaseShowDocument.java:74)::com.cisco.nm.util.async.AsyncIterator.haltIterationWithSuccess(AsyncIterator.java:87)::com.cisco.nm.util.async.AsyncIterator.processLoopInternal(AsyncIterator.java:39)::com.cisco.nm.util.async.AsyncIterator.continueIteration(AsyncIterator.java:72)::com.cisco.nm.pal.customhandler.cli.CLIHandlerImplBaseShowDocument.sessionRunnerCallbackResult(CLIHandlerImplBaseShowDocument.java:151)::com.cisco.xmp.utilities.sessionrunner.XMPCustomSessionRunner$XMPCacheCLIHandlerCallback.sessionRunnerCallbackResult(XMPCustomSessionRunner.java:79)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:305)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionStopSuccess(SessionRunnerWorker.java:236)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopSuccess(CliSessionContextBase.java:96)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopSuccess(CliTransportCommunicator.java:227)::com.cisco.nm.pal.cli.transport.ssh2.CliTransportProviderAsyncSSH2.stop(CliTransportProviderAsyncSSH2.java:258)::com.cisco.nm.pal.cli.transport.CliTransportCommunicator.stopAsync(CliTransportCommunicator.java:112)::com.cisco.nm.pal.cli.session.CliSessionContextBase.stopAsync(CliSessionContextBase.java:91)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveSession.stopAsync(CliInteractiveSession.java:35)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.continueTidyUp(SessionRunnerWorker.java:275)::com.cisco.nm.pal.cli.runner.SessionRunnerWorker.sessionRunCommandSuccess(SessionRunnerWorker.java:199)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveShowCommandRunner.runInteractiveCommandsAsyncSuccess(CliInteractiveShowCommandRunner.java:80)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.succeeded(CliInteractiveCommandRunner.java:281)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.responseReceived(CliInteractiveCommandRunner.java:219)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner.access$000(CliInteractiveCommandRunner.java:23)::com.cisco.nm.pal.cli.session.interactive.CliInteractiveCommandRunner$MainCommandCallback.expectResult(CliInteractiveCommandRunner.java:30)::com.cisco.nm.pal.cli.transport.CliTransportCommunicatorExpectEngine$1.run(CliTransportCommunicatorExpectEngine.java:151)::java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)::java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)::com.cisco.nm.run.threadpool.ThreadPool$PooledThread.run(ThreadPool.java:60)
inventory.log:[2017-09-11 16:01:30,288] [XDE ThreadPool 10] [inventory] [ERROR] - Exception executing function [ethernetextra]interfaceCLI runId 10858579 in time 1799 hook time 136  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 16:01:30,288] [XDE ThreadPool 10] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log:[2017-09-11 16:01:30,288] [ICE Service - Network 1] [inventory] [ERROR] - Feature = feature_config_interface and Procedure = ethernetextra.interfaceCLI with the following error and continuing with other features: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException  deviceId: 824835; CredentialId: 824835; ManagementIP: 172.24.128.1
inventory.log-[2017-09-11 16:01:30,289] [ICE Service - Network 1] [inventory] [ERROR] - Exception Stack: com.cisco.nm.expression.function.FunctionException: java.lang.reflect.InvocationTargetException
inventory.log-[2017-09-11 16:01:37,769] [XDE ThreadPool 17] [AssociationBuilderUtil] [ERROR] - Cannot locate the ICE metadata file: /ice-metadata/ifm_networkservices_technologies_trustsec/ifm_networkservices_technologies_trustsec.xml.
noAppender.log-Caused by: com.cisco.nm.pal.client.PALException: <palError><deviceId>67070</deviceId><code>HANDLER_ERROR</code><itemLocation>[com.cisco.xmp.config.xde.system-bootstrap]mib2-getSysOID.xpa/getSysOID/getSysOID.par@Rule0/HandlerChain/Handler2</itemLocation><message>Get Scalar Operation[Op ID: 5271271]  Received no response from 172.24.146.9/161</message><handlerCode>ERROR_NO_RESPONSE</handlerCode></palError>
noAppender.log-2017-09-08 12:37:56,392 [pooledTaskScheduler-26] ERROR TaskRunnable - Could not invoke method public final com.cisco.xmp.inventory.ice.IceStatus com.sun.proxy.$Proxy85.collectDeviceInventoryInCurrentThread(java.lang.String,java.util.List) throws com.cisco.xmp.inventory.ice.InventoryException,com.cisco.xmp.inventory.ice.PostCollectionHookException on target com.cisco.xmp.inventory.ice.InventoryCollectorEngineServiceImpl$$EnhancerByCGLIB$$cd851df1@5b5d68a with parameters [824835, null]. Exception java.lang.reflect.InvocationTargetException
noAppender.log-2017-09-08 12:37:56,392 [pooledTaskScheduler-26] ERROR TaskUtils$LoggingErrorHandler - Unexpected error occurred in scheduled task.
Hello!
Can you please share the troubleshooting for this? I am having the same issue.
Best Regards,
Parthiv Shah
IF all devices showing unknown then there could be one of the following mismatch between device and Alice-em config
- username / paasword
- snmp community
ccould you make sure that it is correct and confirm whether you changed any of the above after initial discovery?
