IOS-XE telemetry doesnt work
I'm trying to run simple monitoring with Telemetry, by looking at this video: https://www.youtube.com/watch?v=erTyK0WDsT0&t=2556s
I've configured everything, but Cisco device doesn't send any packet to the receiver. The server side uses Influxdb + Telegraf. Config on Cisco looks as follows:
RTR02#  show running-config | section netconf
netconf-yang
RTR02#   show running-config | section telemetry
telemetry ietf subscription 1
 encoding encode-kvgpb
 filter xpath /process-cpu-ios-xe-oper:cpu-usage/cpu-utilization/five-seconds
 source-address 10.254.34.104
 stream yang-push
 update-policy periodic 500
 receiver ip address 10.34.35.239 57000 protocol grpc-tcp
the only thing i dont like is this error:
RTR02#show  telemetry ietf subscription 1 receiver
Telemetry subscription receivers detail:
  Subscription ID: 1
  Address: 10.34.35.239
  Port: 57000
  Protocol: grpc-tcp
  Security profile:
  State: Disconnected
  Explanation: Connection setup failed
The reachability to receiver node (Telegraf) works good.
TR02#telnet 10.34.35.239 57000 /source-interface loopback 100
Trying 10.34.35.239, 57000 ... Open
Also, i've tried to do packet capture on IOS-XE, seems it doesnt even send a packet towards receiver.
Webinar recording from Cisco NetAcad IPD Week Feb 2021 Contents: -Why network monitoring is changing -Brief introduction to TICK stack -Network infrastructure case and demo Link to webinar presentation: https://drive.google.com/file/d/1i_BS58Oiu-T6W7RCSCLahYshpIPuKa_R/view?usp=sharing #NSALAB #CML
6 Replies 6
@EdvinasKairys11982 what does `show platform software yang-management process` show? This document will help also, https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/173/b_173_programmability_cg/model_driven_telemetry.html
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
thanks you, i'm reading lots of manuals, bet nothing new.
first it was showing:
confd            : Running
nesd             : Running
syncfd           : Running
ncsshd           : Running
dmiauthd         : Running
nginx            : Not Running
ndbmand          : Running
pubd             : Running
But after I enabled the ip http server, the nginx changed to running:
confd            : Running
nesd             : Running
syncfd           : Running
ncsshd           : Running
dmiauthd         : Running
nginx            : Running
ndbmand          : Running
pubd             : Running
also tried to reconfigure all telemetry configuration - same situation, it still doesnt work.
any ideas ?
@EdvinasKairys11982 it sounds like a routing issue, what VRF is your source in?
There're only default table, but it's divided into two OSPF instances. I'm thinking if that could be a 'problem' for IOS-XE ?
its reachable:
Could you specify which IOS-XE version are you using?
Could you execute those commands  then put the output ?
show telemetry ietf subscription 1 detail
hello, thanks.
the version is:
IOS-XE Version 16.9.3
Maybe my version is too old for telemetry, i heard that newer, for example 16.10 supports something like GRPC Dial out, maybe that would help. I'm planning to upgrade my device to latest version.
RTR02#show telemetry ietf subscription 1 detail
Telemetry subscription detail:
  Subscription ID: 1
  Type: Configured
  State: Valid
  Stream: yang-push
  Filter:
    Filter type: xpath
    XPath: /process-cpu-ios-xe-oper:cpu-usage/cpu-utilization/five-seconds
  Update policy:
    Update Trigger: periodic
    Period: 500
  Encoding: encode-kvgpb
  Source VRF:
  Source Address: 10.254.34.104
  Notes:
  Receivers:
    Address          Port             Protocol         SecurityProfile
    10.34.35.239     57000            grpc-tcp
  Subscription ID: 1
  Port: 57000
  Protocol: grpc-tcp
  Security profile:
  State: Disconnected
it shows that the connection setup failed, but i dont know the reason, debug doesnt show anything.
