el 11-03-2022 09:37 AM
I have a Cisco ISE in a virtual machine, and I have version 2.4. I want to update the IOS. Is there any documentation on what steps to follow?
¡Resuelto! Ir a solución.
el 11-04-2022 06:58 AM
You can upgrade from 2.4 to 3.0 directly but it is recommended to install the latest patch as you can see in this link:
https://community.cisco.com/t5/security-knowledge-base/ise-version-upgrade-matrix/ta-p/3653501
Below you will find some interesting links to upgrade procedure:
https://www.yaklin.ca/2021/12/27/cisco-ise-2x-to-3x-upgrade.html
https://www.youtube.com/watch?v=gmWXJpbBHrc
Hope it is useful.
el 11-03-2022 10:20 AM
what verion you looking to upgrade.
If you looking to go 3.0 that is latest and (newwer also available)
ISE 3.0 spec have changed, i suggest to build new VM rather Upgrade and wasting time.
Hope it is useful.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
