cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Cisco ISE VmWare Upgrade
eperezb
 I have a Cisco ISE in a virtual machine, and I have version 2.4. I want to update the IOS. Is there any documentation on what steps to follow?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
You can upgrade from 2.4 to 3.0 directly but it is recommended to install the latest patch as you can see in this link:
https://community.cisco.com/t5/security-knowledge-base/ise-version-upgrade-matrix/ta-p/3653501
Below you will find some interesting links to upgrade procedure:
https://www.yaklin.ca/2021/12/27/cisco-ise-2x-to-3x-upgrade.html
https://www.youtube.com/watch?v=gmWXJpbBHrc
Hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
balaji.bandi
what verion you looking to upgrade.
If you looking to go 3.0 that is latest and (newwer also available)
ISE 3.0 spec have changed, i suggest to build new VM rather Upgrade and wasting time.
BB
Hope it is useful.
