CallAddress and CurrentCalledAddress are empty - CallCtlConnDialingEv
Zygmuntix
Frequent Visitor
Frequent Visitor
I have a problem in the code with CallCtlConnDialingEv.
This is my code for getting calledAddress:
String callCalled = Optional.ofNullable(ciscoCall.getCalledAddress()).map(Address::getName).orElse("!EMPTY!");
My code for getting currentCalledAddress:
String callCurrentCalled = Optional.ofNullable(ciscoCall.getCurrentCalledAddress())
.orElse("!EMPTY!");
 The customer is using Cisco UCCE and is making outbound calls.
Some call events for outbound calls contain some normal address (not null), but sometimes the getCalledAddress() and getCurrentCalledAddress() return null. Why is it like that (so random)?
dstaudt
First thought might be that the results may depend on timing.  E.g. if you get a new call event after the call has been created, but before it has been connected/dialed, the values would be null.  Might try waiting for particular call progress events (e.g. CallCtlTermConnRingingEv) before doing getCalledAddress().
It would be good to know if there are any differences in call scenario (e.g. direct make call vs. transfer vs. conference) that seem to map to null values...
The JTAPI Test Tool can be helpful in examing/testing live calls/events/methods.
