Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
I am testing curri and external call control, if i put external call control in translation pattern or route pattern with 0.! , if i digit from my phone 034 immediatly cm make a request to my test application, but i need to digit 03456etc number. for...
maurotb by • Frequent Visitor
  • 887 Views
  • 1 replies
Hello Everyone, Can anyone help me with the Lua scripting. I have created the below response normalization Lua script.  M={}function M.outbound_404_INVITE(msg)msg:setResponseCode(406, "Not Accepted")endreturn M This is applied on the SIP trunk to the...
RG84 by • Community Member
  • 3746 Views
  • 2 replies
Hello Folks!I working on a project where I required a little input from your side!We have created cucm cluster having one publisher followed by three subscribers! I wanted to implement this thing via JTAPI which actually has 1 provider for each cucm!...
AbbasMalik by • Frequent Visitor
  • 1058 Views
  • 1 replies
Hello,New this devnet .I have come across issue with CVP server  were i got the below error from log. Enclosed complete log for your  ref."can't connect to SIP server: ConnectionWrapper.check: can't establish connection"During this issue my vru pim i...
manjunathc24 by • Frequent Visitor
  • 5027 Views
  • 7 replies
Hi Team, I have a question regarding the following compatibility document: https://developer.cisco.com/site/tapi/documents/supported-windows-os/   is TAPI 11.5/12.0/12.5 supported with all of the Windows 10 types/version (LTSC/B, CBB ...)? I have a s...
eyalraba by • Cisco Employee
  • 2110 Views
  • 1 replies
I'm looking to replicate the output of the IM&P Presence Usage report, a list of active or signed in Jabber / XMPP clients via an API or some other programmatic method. While querying the CUCM RISDB can return clients currently registered to CUCM for...
I have a unique issue regarding SIP Diversion headers generated by Call Manager.  We have a department using Contact Center Express, and one of the features written into the CCX script for the agents is the ability of the caller to exit the queue and...
mnora by • Frequent Visitor
  • 2890 Views
  • 4 replies
Hi All, Currently utilising CURRI via Python 2.7 - working fine. However, have a requirement to migrate to Python 3.x for compliance reasons.Unfortunately, the SocketServer application no longer functions as expected in 3.x.I've ran all code via 2to3...
Hello Community, I have been reading CURRI documentation and I found that it is possible to modify the calling number and called number using CURRI, to apply business rules. I tested it calling from one internal agent to another successfully, but I c...
mcalderon by • Community Member
  • 2091 Views
  • 1 replies
