CUCM forwarding Call to another ITSP via SIP Manipulation
Gura24
I have to use a phone number from provider1 but I must route the external calls to provider 2.
1) On CUCM Site 2 is a phone with DN from provider 1
2) Call Flow:
- Call - Provider1 -> CUCM Site 1 -> CUCM Site 2 -> Phone on site 2 is ringing
- Phone on site 2 is dailing an external number -> Provider 2 -> External phone is ringing
Provider2 doesnt accept calling IDs from different providers. Is there any way to get this done via SIP Normalization script on CUCM?
Thank you for help!
Cheers
I just fixed that problem. In the INVITE I just added a Devision in the header.
M = {}
function M.outbound_INVITE(msg)
local pai = msg:getHeader("P-Asserted-Identity")
msg:addHeader("Diversion", pai)
end
return M
Now its working also with the correct calling DID!
Thanks for help!
Cheers
dijarvrella
Hi there,
You can do SIP manipulation but the provider 2 will not accept calls that have different originating calling ID from the ones that is provided/assigned from the ITSP provider 2 to that specific SIP trunk.
Do you have an assigned DID from the provider 2?
Dijar
Thanks for quick response!
Yes I have some assigned DIDs from provider 2 as well.
M = {}
end
return M
Thanks for help!
Cheers
After you have to change also the PAI or Diversion Header.
M = {}
ocal diversHeader = msg:getHeader("Diversion")
if diversHeader
then
msg:applyNumberMask("Diversion", "+1234567)
end
end
