Detect incoming call
sigtrm
what would be the easiest/proper way to detect incoming call on PC for given user?
Scenario: user has IP Phone and PC, when call is incoming I would like to detect that and display notification on PC.
I can see there are multiple ways to interact with CUCM, I do now even know where to start.
Can it be done with XML? Or it has to be (J)TAPI?
Can someone point me to right direction?
CUCM 11.5.
valudio.mischa
Hi @sigtrm,
We developed an application which does exactly that.
With TAPI/JTAPI you're going in the right direction.
Which technology are you planning to use. JTAPI is a Java library and TAPI is C++.
Cheers,
Mischa
Hi @valudio.mischa,
I am trying to do exactly the same. I am planning to use JTAPI Java library.
Can you please tell us how exactly does your application detect an incoming call?
Any leads or pointers will be appreciated.
