Disabling Call back ring at runtime
upchaurasia
Is it possible to off/disable callback ring (which play to caller) of a call at runtime? Based on some application logic we want to off callback ring.
Umesh
amoherek
Hi Umesh,
Are asking about Automatic Ring Back or a Ringback Tone?
Adrienne
ashish.nijai
Level 2
Level 2
I think we can send some commands to Cisco IP phone in form of XML to stop call back ring tone.
I did it 7-8 years ago.
I am not sure whether that is available now also.
mencarnacion
Community Member
Hi Umesh,
Have you found a solution for this?
I think I have the same problem as you except for the part the the phone being called should also get it's ringer disabled.
Cheers!
U can disable called phone ring using Axl. When there is call alerting event send XML for volume 0 to called phone using send data.
Umesh
Sent via Xiaomi
