EpStreamCodecInGet issues
denes.istvan
I'm using Cisco's EpApi for sound stream handling for call management. Everything works ok. I can get the streams, start the streams, sound is coming and going.
I have found in the documentation the EpStreamCodecInGet function and implemented the same way as the other EpApi functions. The problem is when I call this function it returns true (so no errors) however, the structure with the WAVEFORMATEX remains empty (it is not changed by the function). Every value is 0. I have called this function before and after EpStreamStart with same result.
What can be the problem?
Istvan
denes.istvan
Also was thinking about, is it possible that this is somehow disabled from the CUCM?
