Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
In our application, we have integrated Cisco switch and for telephony call control have implemented atapi api.When any conference member get disconnected from conference call then event OnCallStateChanged get raised for callstate.idle for all confere...
Hello,I'm using Cisco's EpApi for sound stream handling for call management. Everything works ok. I can get the streams, start the streams, sound is coming and going.I have found in the documentation the EpStreamCodecInGet function and implemented th...
We have a series of devices that have private DNs.  When they make an outbound call to a particular destination, we want to intercept the call, lookup the appropriate callerid for that particular device (based on caller ip address, in our custom purp...
telesteve by • Community Member
  • 1039 Views
  • 1 replies
Calls are being routed to JTAPI extensions but no JTAPI events are received are received for offered, ringing, etc, in spite of observers being registered for this address.  See extension 4912 in the attached jtapi log.Any ideas?Thanks.
Hi there I'm having a big trouble with transfers and JTAPI:In our company we named this scenarion single-step transfer Step 1:Connect via jtapi to cucmRegister CallObserver, AddresObserver, TerminalObserver for extension A, extension BBut not registe...
punin.v.v by • Community Member
  • 1619 Views
  • 1 replies
  • 1 Helpful votes
Hi,We develop a Active Sip Call Recorder, and some client in the past require encrypted call recording too, this Cisco Callmanager uses a token's for encryption, but the current version don't require them for encrypted sip calls, we want to know if t...
Adportas by • Visitor
  • 788 Views
  • 0 replies
Hi Team,  Requirement :    We have a requirement to find the TFTP server host name for the given user id and password. Accomplished as of now :    1. Using User id and Password we were able to identify UCM URL .https://ucm-ap701-bgl.cisco.com:8443/  ...
sbejawad by • Level 1
  • 22233 Views
  • 7 replies
Hello,I'm new to the normalization scripting but I wrote a script to add a diversion header to an outgoing call based on the calling number.  This is a short version of the script:--get contents of To header--if contents of To header is not 911, get ...
nickwarfield by • Frequent Visitor
  • 11873 Views
  • 10 replies
