Getting not enough buffer for response in Sample application
sumitha01
Community Member
I have a problem running the sample code provided by Cisco. Getting an error message "Not enough buffer for response, please config a larger one."
We set the maximum response size in router as 64.
Is there any way to increase the buffer size.
You can refer sample application codes in below location.
Cisco UCXAPI
Raghavendra
Raghavendra G V
Hi Sumitha,
I believe max response size is 64 only, I don't think we can increase. Please check below link.
CUCME XML Api response size and traffic limitation - Community - Cisco Developer Community
Raghavendra
We are trying to develop the basic TAPI-type functionality using UCXSI for our CRM
1. When there is an incoming call, a pop up should appear on the screen
2. Call (internal/external) should be made by clicking on the number on screen.
Is it possible to make/receive externam calls using UCXSI. Please advice.
If you App is just like you described, I think the API should be able to handle that
Cisco UCXAPI
Raghavendra
