Announcement to called number
ivana vidakovic
This is my first encounter with TCL scripting.
I have a cisco router as a voice gateway (H323). It has a E1-ISDN connected to PSTN and a G0/0 to it's LAN. Whenever there is a call from one of the IP Phones to an external number (PSTN), can the voice-gateway play a message to the CALLED party before they start talking? The message should be "This call may be recorded."
Best regards,
Ivana
No, below one is fine you need to add one more for ev_setup_done event.
set fsm(CALL_INIT,ev_setup_indication)  "act_Setup PLACECALL"
Please go through the sample scripts and programming guide which are present in above link.
Raghavendra
8 Replies 8
Raghavendra G V
Hi Ivana,
Yes, you can destroy connection once you got ev_setup_done event, play message to outgoing leg and then create connection.
media play leg_outgoing greating.au
Raghavendra
Hi Raghavendra,
Thank you for your reply.
I think I understand how it would work, however, being new to TCL scripting I am having trouble creating the script. I was hoping you could take a look at it:
# initialize the parameters that configured from IOS CLI
proc init_configs { }  {
    global announcement
    set announcement flash:announcement.au
#destroy connection
proc act_Setup { } {
  global dest
  set dest [infotag get leg_outgoing]
  leg setup $dest callInfo leg_incoming
  connection destroy con_all
#play prompt to called number
proc act_Media { } {
  global announcement
   media play leg_outgoing $announcement
#create connection
  global incoming
  global outgoing
  set incoming [infotag get leg-incoming]
  set outgoing [infotag get leg-outgoing]
  connection create $incoming $outgoing
proc act_CallSetupDone { } {
    puts ">>> Tcl: act_CallSetupDone <<<"
    set status [infotag get evt_status]
    handoff appl leg_all default
    call close
proc act_Cleanup { } {
    call close
init_configs
set fsm(any_state,ev_disconnected)  "act_Cleanup  same_state"
set fsm(PLACECALL,ev_destroy_done) "act_Media PLAYPROMPT"
set fsm(PLACECALL,ev_media_done)  "act_CallSetupDone  CALLACTIVE"
set fsm(CALLACTIVE,ev_disconnected)      "act_Cleanup CALLDISCONNECT"
set fsm(CALLDISCONNECT,ev_disconnected)  "act_Cleanup        same_state"
set fsm(CALLDISCONNECT,ev_media_done)    "act_Cleanup        same_state"
set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup        same_state"
fsm define fsm CALL_INIT
Aslo, if I understand correctly, I would configure this script on the inbound VoIP dial-peer, not on the outbound pots dial-peer?
Best regards,
Ivana
Hi Ivana,
You should destroy connection once you got ev_setup_done. You can refer our sample scripts in below location.
Cisco VGAPI
Raghavendra
Doesn't ev_setup_done indicate that the leg setup command has finished?
This is why I thought I should destroy the connection after eg setup $dest callInfo leg_incoming.
If this is not the case, can you tell me when/where I should destroy the connection?
Also, could you confirm that I configure the application on the inbound VoIP dial-peer?
leg setup command has to be finished then only you can get outgoing leg using  [infotag get leg_outgoing] .
Yes you can configure script under incoming voip dial peer.
Raghavendra
I just noticed I made a mistake.
I should have set fsm(CALL_INIT,ev_setup_done)   "act_Setup PLACECALL" instead of
Is it OK now?
Raghavendra
Hi Ivana,
I was wondering if you were ever able to get this to work?
Jeff
