how to set each jtapi.ini to each peer?
simon_new11
Hi all,
When search the JTAPI api, there is CiscoJtapiProperties#getUniqueJTAPIPropertiesPerPeer().
boolean getUniqueJTAPIPropertiesPerPeer()
This method returns true if the JTAPI is configured to use a unique JTAPIProperties object for each JtapiPeer, or false if JTAP is configured to share a single JTAPIProperties object for all peers.
Returns:
boolean
Since:
9.0
but is there modifier method for it, such as setUniqueJTAPIPropertiesPerPeer(boolean)?
or is there API to configure a unique JTAPIProperties object for each Provider object?
Thanks in advance.
Simon
smupadhy
This configuration is loaded at startup, and cannot be changed once a Peer is created. And so, there appears to be no setter methods for this.
If I find some more information regarding this, I will post it here.
Hi Smita,
According the API, the setting cannot be changed after get provider from peer.
When we get peer from factory, I guess that we can change the content of  properties as bellow code:
  JtapiPeer peer = JtapiPeerFactory.getJtapiPeer(null);
  ((CiscoJtapiPeer)peer).getJtapiProperties();
  properties.setXXX(YYY);
   Provider provider1 = peer.getProvider(connectionStr1);
But for multiple clusters environment, can we use different properties for different providers? is code as bellow the right way?
properties.setXXX(ZZZ);
  Provider provider2 = peer.getProvider(connectionStr2);
Simon
i don't think that will work. All providers would get the last properties set.
In multiple cluster scenario what properties would you like set different?
I have seen applications using 1 JVM per provider which talk to a central component that provides a multiple cluster view.
