LUA Script to modify contact header
fgleanza
Frequent Visitor
Frequent Visitor
Dear, I need to make a script to modify the contact header field,
I need to remove the string "+ sip.instance =" <urn: uuid: 832028f41e6258c46e8de1e8dd3d6723360b5c74> "; reg-id = 1"
String before normalizing:
Contact: <sip: [email protected]: 50772>; + sip.instance = "<urn: uuid: 832028f41e6258c46e8de1e8dd3d6723360b5c74>"; reg-id = 1
String after normalizing
Contact: <sip: [email protected]: 50772>; q = 1
Could you help me put the script together?
Thank you very much
18 Replies 18
I'm not sure what this is, but you haven't shared an SDL trace.  Please download using RTMT...
Ok, thanks
I've had confirmation that they are supported for phones as well (am still confirming 3rd-party device support).  Can you please apply to the SIP Profile for the device, and do an SDL capture and share this?  I reckon we should be able to get this working, or at least do an analysis and check!
I think it is better to have the original trace of the REGISTER message, in my case, I have "q=1", not "q = 1". it is case sensitive.
