Multiple Diversion Headers with " and , in values
Chris Bomba
Level 4
Level 4
We are trying to apply a normalization script that removes all but the last Diversion header.  The problem is that our DH's contain "Lastname, Firstname" in them and that is screwing up the script.  How do I ignore the " and the , in the DH so I end up with an array result of DiversArray[1] and DiversArray[2]?  Also, is there a  way to add a domain to the end of "sip:LastnameF@10.95.249.32" so that the SIP URI is sent to Unity Connection?  Since CUC is 10.5, I am syncing the SIP URIs from LDAP as Alternate Extensions.  The script in use is:
Script:
M = {}
function M.outbound_INVITE(msg)
    local DiversArray = msg:getHeaderValues("Diversion")
    local DiversCount = #DiversArray
    if DiversCount > 1 then
        for I = 1, (DiversCount - 1) do
            msg:removeHeaderValue("Diversion", DiversArray[I])
        end
    end
end
return M
The incoming Invite:
INVITE sip:10072@10.95.249.120:5065 SIP/2.0
Via: SIP/2.0/TCP 10.95.249.32:5065;branch=z9hG4bK3466886ed1e5bd
From: "Chris Bomba" <sip:19297@10.95.249.32>;tag=5197421~eabeda24-350b-4a32-bee7-488ec9eff82b-57346743
To: <sip:10072@10.95.249.120>
Date: Tue, 02 Sep 2014 18:09:15 GMT
Call-ID: 3e661d00-406107cb-220803-20f95f0a@10.95.249.32
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:10.95.249.32:5065>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1046879488-0000065536-0000162743-0553213706
Session-Expires:  1800
Diversion: "lastname, firstname" <sip:lastnamef@10.95.249.32>;reason=no-answer;privacy=off;screen=no
Diversion: "lastname, firstname" <sip:15350@10.95.249.32>;reason=no-answer;privacy=off;screen=yes
P-Asserted-Identity: "Chris Bomba" <sip:19297@10.95.249.32>
Remote-Party-ID: "Chris Bomba" <sip:19297@10.95.249.32>;party=calling;screen=yes;privacy=off
Contact: <sip:19297@10.95.249.32:5065;transport=tcp>;video;audio;bfcp
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 1449
The resulting Invite after script:
Via: SIP/2.0/TCP 10.95.249.32:5065;branch=z9hG4bK347ebf311e78fa
From: "Chris Bomba" <sip:19297@10.95.249.32>;tag=5205025~eabeda24-350b-4a32-bee7-488ec9eff82b-57350235
Date: Tue, 02 Sep 2014 18:52:16 GMT
Call-ID: 40cb7580-406111e0-221468-20f95f0a@10.95.249.32
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 1087075712-0000065536-0000163179-0553213706
Diversion: firstname" <sip:lastnamef@10.95.249.32>;reason=no-answer;privacy=off;screen=no
Diversion: firstname" <sip:15350@10.95.249.32>;reason=no-answer;privacy=off;screen=yes
Max-Forwards: 69
Because of the "Lastname, Firstname" in the Diversion Header we get and error when parsing:
39762672.002 |15:12:50.581 |AppInfo  |//SIPLua/Info/SipMessage_removeHeaderValue: API failure(-5) for Device: Unity_Connection_SIPTrunk_01 Script: UseLastDiversion callid 2050ea80-406116b2-2219c2-20f95f0a@10.95.249.32 header 'Diversion' value ' Firstname" <sip:Lastnamef@10.95.249.32>;reason=no-answer;privacy=off;screen=no'
39762672.003 |15:12:50.581 |AppInfo  |//SIPLua/Info/SipMessage_removeHeaderValue: API failure(-5) for Device: Unity_Connection_SIPTrunk_01 Script: UseLastDiversion callid 2050ea80-406116b2-2219c2-20f95f0a@10.95.249.32 header 'Diversion' value '"Lastname'
Geevarghese Cheria
   From your post what i understand is that you are looking for the logic to remove extra Diversion Headers which contains lastname and firstname. Found a bug - CSCtd31096 for a similar kind of issue
I would request you to refer https://supportforums.cisco.com/node/12151771  for related information.
Thanks and Regards,
Geevarghese
We worked with our local Cisco team to fix the normalization script.  Now it looks for the comma and splits the header.  We then delete the Diversion header and add it back in.  The comma was definitely causing the issue.
