Setting call MLPP precedence ?
paolo bevilacqua
There is an undocumented infotag (leg_precedence_info) to to get MLPP precedence of an incoming call.
Is there a way to directly set MLPP precedence for an outgoing call, like a callInfo element ?
Currently I set SIP MLPP headers via callInfo(protoHeader), but the limitation is that for calls made to FXS on the same router the destination will fast ring only if the leg setup is done with autoconferencing to a leg that has precedence already.
Raghavendra G V
Addressed this issue in below thread.
https://communities.cisco.com/thread/55371
Raghavendra
