Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
There is an undocumented infotag (leg_precedence_info) to to get MLPP precedence of an incoming call.Is there a way to directly set MLPP precedence for an outgoing call, like a callInfo element ?Currently I set SIP MLPP headers via callInfo(protoHead...
Hello!I'm trying to download Jtapi from the next page:Download - Cisco Unified Communications Manager - Cisco SystemsBut all the download links are broken and it returns 404Is there another place where I can download it?Best Regards.
Hi all,When search the JTAPI api, there is CiscoJtapiProperties#getUniqueJTAPIPropertiesPerPeer().boolean getUniqueJTAPIPropertiesPerPeer()This method returns true if the JTAPI is configured to use a unique JTAPIProperties object for each JtapiPeer, ...
simon_new11 by • Community Member
  • 1217 Views
  • 3 replies
Hi,I'm investigating how we could leverage in my company the JTAPI to drive the recording to follow a schedule which would be stored in an external database.I've read that a recording configuration is available for "Application-controlled recording",...
kadala001 by • Community Member
  • 616 Views
  • 1 replies
Hi team,I have a basic TCL script that works as an IVR with option menu.After the caller selected the option,  the call is point to a hunt group.Each hunt group (SIP) has three extension numbers (hunt-list) with 15 seg of waiting time, almost 3 rings...
dsobrinho by • Level 10
  • 859 Views
  • 1 replies
  • 1 Helpful votes
We have two CUBE routers and use TCL IVR to handle some of the inbound SIP call.While testing we found that , if the caller disconnects while the message is being played , the transfer is still initiated and target phone rings for few seconds [ 6 rin...
Linli Zhao by • Frequent Visitor
  • 1534 Views
  • 1 replies
Hi,We are using cisco jtapi api, while calling a invalid number i am getting the following exception,com.cisco.jtapi.PlatformExceptionImpl: Could not meet post conditions of connect()at com.cisco.jtapi.CallImpl.connect(CallImpl.java:1115)at com.cisco...
lokessri by • Community Member
  • 897 Views
  • 1 replies
I have a 2901 with IOS 15.0(1r)M16 with CME (telephony services version 8.6), And I have been trying to emulate the way Nortel manages pin numbers, and so far, I think the only way of achieving this on the CME, is to have a custom script to capture t...
