TCL example its-CISCO issue
jvazquez
Hello i trying to use example its-CISCO and i getting next error .. any idea ??? general configure information below error
thanks in advence
*Feb 25 19:38:36.547: //187//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
*Feb 25 19:38:36.551:
*Feb 25 19:38:36.551: //187//TCL :/tcl_PutsObjCmd:
ANI sip:30110@172.20.5.22
DNIS sip:5555@172.20.5.30:5060
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_GetUsrContainerData: Container is present, No data
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
*Feb 25 19:38:36.555: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 25 19:38:36.559: //187//TCL :/tcl_PutsObjCmd:
Call failed.  Play prompt and collect digit
*Feb 25 19:38:36.563: //187//TCL :/tcl_PutsObjCmd:
proc act_Select
proc act_DestBusy
*Feb 25 19:38:36.567: //187/EC1D68000000/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
SIP: (187) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
*Feb 25 19:38:36.587: //187/EC1D68000000/SIP/Error/sipSPIProcessAckMedia: Could not modify QoS params for midca
service test its-CISCO.tcl
  paramspace english index 1
  paramspace english lenguage en
  paramspace english location flash:
  param aa-pilot 5555
  param operator 9998
dial peer
dial-peer voice 5555 voip
service test
session protocol sipv2
incoming called-number 5555
dtmf-relay rtp-nte
codec g711ulaw
no vad
GW version 151-4.M10
17 Replies 17
*Feb 27 00:27:45.870: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=0,
   Source Call Id=209, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x0, Rtp Expiration=0x0
*Feb 27 00:27:45.870: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:45.870: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:45.870: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:45.870: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:45.874: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:45.874: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:45.874: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:45.874: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:45.874: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:46.010: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
   Source Call Id=209, Digit=3, Duration=160,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
*Feb 27 00:27:46.010: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:46.010: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:46.014: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:46.014: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:46.014: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
               mediaStream=0x6A295288, rtspStream=0x6847CC44
               reason=MSW_RECRD_REASON_INTERRUPTED current_state=MSW_S_IDLE
*Feb 27 00:27:46.014: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:46.014: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:46.014: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:46.014: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:46.018: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:46.018: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:46.018: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:46.018: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:46.018: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:46.018: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696D9DFC_0_73558152
*Feb 27 00:27:46.018: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:46.018: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 3 Tone Mode 0
*Feb 27 00:27:46.018: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:46.018: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=3333
*Feb 27 00:27:46.018: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:46.018: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:46.018: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696D9DFC_0_73558152 ---> NULL
*Feb 27 00:27:46.018: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:46.022: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:47.130: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
   Source Call Id=209, Digit=2, DigitBeginFlags=0x0,
*Feb 27 00:27:47.130: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.130: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:47.130: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:47.134: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.134: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.134: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:47.134: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:47.134: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.134: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:47.270: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
   Source Call Id=209, Digit=2, Duration=160,
*Feb 27 00:27:47.270: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.274: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:47.274: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:47.274: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:47.274: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
*Feb 27 00:27:47.274: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:47.274: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.274: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:47.274: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:47.278: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:47.278: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.278: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:47.278: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.278: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:47.278: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696D9DFC_0_73558152
*Feb 27 00:27:47.278: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:47.278: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 2 Tone Mode 0
*Feb 27 00:27:47.278: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:47.278: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=33332
*Feb 27 00:27:47.278: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:47.278: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:47.278: //209/9DE891800000/AFW_:/AFW_Leg_DigitReportDisable: Current: 0x2 Input: 0x1
*Feb 27 00:27:47.282: //209/9DE891800000/CCAPI/ccCallReportDigits:
   (callID=0xD1, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Call Id=209
*Feb 27 00:27:47.282: //209/9DE891800000/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68263008, callID=0xD1, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x68263008, Call Id=209
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
*Feb 27 00:27:47.282: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696D9DFC_0_73558152 ---> NULL
*Feb 27 00:27:47.282: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.282: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:47.282: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.282: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:47.282: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
*Feb 27 00:27:47.282: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.282: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.282: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:47.282: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:47.282: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.286: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.286: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:47.286: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.286: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:47.286: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:47.286: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.286: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:47.286: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696D9DFC_0_73558152
*Feb 27 00:27:47.286: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:47.286: //209//Digi:/act_DCRunning_RDone: id=209 Reporting disabled.
*Feb 27 00:27:47.286: //-1//Digi:/DigitCollect_Complete: DC_MATCHED_DIALPLAN. Digits=33332
*Feb 27 00:27:47.286: //209//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
*Feb 27 00:27:47.286: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done
*Feb 27 00:27:47.286: //209//AFW_:/AFW_Module_ReturnArgEv:
*Feb 27 00:27:47.286: //209//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[209    ][LEG_INCCONNECTED(5)][Cause(0)]}
*Feb 27 00:27:47.286: //209/9DE891800000/AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:27:47.286: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 27 00:27:47.290: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696D9DFC_0_73558152 ---> NULL
*Feb 27 00:27:47.290: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.290: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:47.290: //209//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 27 00:27:47.290: //209//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DIGITCOLLECT_DONE(228)] {
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 27 00:27:47.290: //209//Digi:/AFW_M_DigitCollect_EventPreProcess:
*Feb 27 00:27:47.290: //209//Digi:/DigitCollectEnd_UpdateStats:
*Feb 27 00:27:47.290: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.290: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696D9DFC_0_73558152]  (
*Feb 27 00:27:47.290: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:47.290: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.290: //209//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 27 00:27:47.290: //209/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 27 00:27:47.294: //209//AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:27:47.294: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 1
*Feb 27 00:27:47.294: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:27:47.294: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:27:47.294: //209//AFW_:/AFW_TclModule_DefaultEvHandling:
*Feb 27 00:27:47.294: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(GETDEST[3],ev_collectdigits_done[228])---[act_GotDest]------
*Feb 27 00:27:47.294: //209//TCL :/tcl_PutsObjCmd:
proc act_GotDest
*Feb 27 00:27:47.294: //209//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
*Feb 27 00:27:47.294: //209//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
*Feb 27 00:27:47.294: //209//AFW_:/vtr_ev_status: argc 2 argindex 2
STATUS: cd_004
MAXEXTENSION: 13
*Feb 27 00:27:47.294: //209//TCL :/tcl_InfotagObjCmd:  infotag get evt_dcdigits
*Feb 27 00:27:47.294: //209//TCL :/tcl_InfotagGetObjCmd: infotag get evt_dcdigits
*Feb 27 00:27:47.294: //209//AFW_:/vtr_ev_dcdigits: argc 2
*Feb 27 00:27:47.294: //209//AFW_:/vtr_ev_dcdigits: DCDIGITS [33332]
DESTLEN: 5
extLength: 8
*Feb 27 00:27:47.298:
*Feb 27 00:27:47.298: //209//TCL :/tcl_PutsObjCmd:
DIGITS: 33332
*Feb 27 00:27:47.298: //209//TCL :/tcl_LegObjCmd:  leg setup 33332 callInfo leg_incoming
*Feb 27 00:27:47.298: //209//CSPK:/tcl_LegSetupObjCmd: leg setup 33332 callInfo leg_incoming
*Feb 27 00:27:47.298: //209//AFW_:/vtd_lg_incoming: argc 4
*Feb 27 00:27:47.298: //209//AFW_:/vtd_lg_incoming: Legs [209 ]
*Feb 27 00:27:47.298: //209//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 27 00:27:47.298: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied
*Feb 27 00:27:47.298: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(6949F0A8)
*Feb 27 00:27:47.298: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(6A29B56C) created in usrContainer(6949F0A8)
*Feb 27 00:27:47.298: //-1//AFW_:/AFW_Util_GetUsrContainerData: Container is present, No data
*Feb 27 00:27:47.298: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: Successful in setting 'CC_TAG_SETUP_REQ_DATA' in usrContainer(6949F0A8)
*Feb 27 00:27:47.298: ccDumpTdRequestDataGen:
*Feb 27 00:27:47.298:   called_urip=NULL
*Feb 27 00:27:47.298:   calling_urip=sip:30110@172.20.5.22
*Feb 27 00:27:47.298: url_dump_header_line_avpair:
*Feb 27 00:27:47.298:   num_bodies = 0
*Feb 27 00:27:47.298: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
*Feb 27 00:27:47.298: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
*Feb 27 00:27:47.302: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
*Feb 27 00:27:47.302: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
*Feb 27 00:27:47.302: //209//CSPK:/C_CallSetup_Start: ControlInfo = 0x6A439108, callInfo = 0x6A3F82AC, destination[0]=33332
*Feb 27 00:27:47.302: //209//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
*Feb 27 00:27:47.302: //209//CSPK:/C_CallSetup_Start: configured reroutemode=rotary (1)
*Feb 27 00:27:47.302: //-1//Call:/AFW_CallSetup_New:
*Feb 27 00:27:47.302: //-1//AFW_:/AFW_FSM_New:
*Feb 27 00:27:47.302: //-1//AFW_:LP:EE681ABEBC000:HN0462AF5C:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
*Feb 27 00:27:47.302: //209//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
*Feb 27 00:27:47.302: //209//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 27 00:27:47.302: //209//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_6A3524D0_0_73576284
*Feb 27 00:27:47.302: //209//Call:/AFW_CallSetup_AddDest:  33332 index 0
*Feb 27 00:27:47.302: //209//Call:/AFW_CallSetup_SetIntWrkLeg:
*Feb 27 00:27:47.302: //209/9DE891800000/AFW_:/AFW_Leg_SignalPeerGet: Leg [209]
*Feb 27 00:27:47.302: //-1//AFW_:/C_PackageSession_GetSigPeer:
*Feb 27 00:27:47.302: //209/9DE891800000/AFW_:/C_PackageSession_GetSigPeer: No Interworking module on Leg, no signal peer
*Feb 27 00:27:47.306: //209//Call:/AFW_M_CallSetup_Initiate:
*Feb 27 00:27:47.306: //209/9DE891800000/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
*Feb 27 00:27:47.306: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 27 00:27:47.306: //209//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
*Feb 27 00:27:47.306: //209//Call:/CallSetupInitiate:
*Feb 27 00:27:47.306: //209//Call:/CS_Placecall:
*Feb 27 00:27:47.306: //-1//Dest:/AFW_Destination_New:
*Feb 27 00:27:47.306: //-1//AFW_:/AFW_FSM_New:
*Feb 27 00:27:47.306: //-1//AFW_:LP:EE681ABEBC000:HN0462AF60:/AFW_M_Object_SetExecEnv: ObjCount: 5, CmdPending 2
*Feb 27 00:27:47.306: //209//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
*Feb 27 00:27:47.306: //209//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
*Feb 27 00:27:47.306: //209//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.306: //209//Dest:/AFW_Destination_AddDest:
*Feb 27 00:27:47.306: //-1//Dest:/AFW_Destination_AddDest: adding destination "33332"
*Feb 27 00:27:47.306: //209//Dest:/AFW_Destination_SetIntWrkLeg: LEG[209    ][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.310: //209//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
*Feb 27 00:27:47.310: //209//Dest:/DestSetIntWrkLeg:
*Feb 27 00:27:47.310: //209/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
*Feb 27 00:27:47.310: //209//Dest:/AFW_M_Destination_Initiate:
*Feb 27 00:27:47.310: //-1//AFW_:/AFW_Util_SaveRawMsg:
*Feb 27 00:27:47.310: //209//Dest:/AFW_M_Destination_Initiate: Outgoing guid : 9DE89180.00010000.00000099.160514AC
*Feb 27 00:27:47.310:  Incoming_guid : 00000000.00000000.00000000.00000000
*Feb 27 00:27:47.310: //209//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : B7DB0478.DC1F11E5.813EF06D.617340D4
*Feb 27 00:27:47.310:  Incoming_gcid : 00000000.00000000.00000000.00000000
*Feb 27 00:27:47.310: //209/9DE891800000/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
*Feb 27 00:27:47.310: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 27 00:27:47.310: //209//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
*Feb 27 00:27:47.310: //209//Dest:/DestSetupInitiate:
*Feb 27 00:27:47.310: //209//Dest:/DestAddRerouteSetupInfo:
*Feb 27 00:27:47.310: //209//Dest:/DestAddTransferSetupInfo:
*Feb 27 00:27:47.310: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 33332
*Feb 27 00:27:47.310: //209//Dest:/DestMatchDialPeer:
*Feb 27 00:27:47.310: //209//Dest:/DestMatchDialPeer: src carrier id:, tgt carrier id:
*Feb 27 00:27:47.310: //209//Dest:/DestQueuePeers: Matched peers:
*Feb 27 00:27:47.310: //209//Dest:/DestPeerItemUpdatePreemptInfo:
*Feb 27 00:27:47.310: //209//Dest:/DestPeerItemResetLPCORInfo:
*Feb 27 00:27:47.314: //-1//Dest:/DestQueuePeers:  3333
*Feb 27 00:27:47.314: //-1//Dest:/DestQueuePeers: , Total(1)
*Feb 27 00:27:47.314: //209//Dest:/DestDialPeerRotary:
*Feb 27 00:27:47.314: //209//Dest:/DestOutboundCallUsingPeer: dest(33332), numexpDest(33332), numDestDigits(1)
*Feb 27 00:27:47.314: //209//Dest:/DestOutboundCallUsingPeer:    prefix(.22), peer tag(3333)
*Feb 27 00:27:47.314: //209//Dest:/DestUpdatePreemptSetupInfo:
*Feb 27 00:27:47.314: //-1//AFW_:/AFW_Util_RemovePreemptInfoFromContainer: Failed to remove mlppSetupInfo from TD container
*Feb 27 00:27:47.314: //209//Dest:/DestDialPeerFilter:
*Feb 27 00:27:47.314: //209//Dest:/DestDialPeerFilter: Checking peer [3333]
*Feb 27 00:27:47.314: //209//Dest:/DestPeerFilterRouteCode: Route Code not available
*Feb 27 00:27:47.314: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(3333) calling[30110] called[33332]
*Feb 27 00:27:47.314: //209//Dest:/DestCheckTeleUnassBusy:
*Feb 27 00:27:47.314: //209//Dest:/DestHandleLPCOR:
*Feb 27 00:27:47.314: //209//Dest:/DestSetup:
*Feb 27 00:27:47.314: //-1//AFW_:/AFW_Leg_New:
*Feb 27 00:27:47.314: //209/9DE891800000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3333, Params=0x696BA008, Progress Indication=NULL(0)
*Feb 27 00:27:47.314: //209/9DE891800000/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:30110@172.20.5.22(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:30110@172.20.5.22(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=3...., Called Number=33332, Digit Strip=FALSE
   Calling Number=sip:30110@172.20.5.22(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33332(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=30110, Final Destination Flag=TRUE,
   Guid=9DE89180-0001-0000-0000-0099160514AC, Outgoing Dial-peer=3333
*Feb 27 00:27:47.314: //209/9DE891800000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=30110
   ----- ccCallInfo IE subfields -----
   cisco-ani=sip:30110@172.20.5.22
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=33332
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Feb 27 00:27:47.318: //209/9DE891800000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x68263008, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:30110@172.20.5.22,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33332(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3333, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Feb 27 00:27:47.318: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 27 00:27:47.318: :cc_get_feature_vsa malloc success
*Feb 27 00:27:47.318:  cc_get_feature_vsa count is 2
*Feb 27 00:27:47.318: :FEATURE_VSA attributes are: feature_name:0,feature_time:1729742688,feature_id:106
*Feb 27 00:27:47.318: //212/9DE891800000/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Feb 27 00:27:47.318: //212/9DE891800000/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
*Feb 27 00:27:47.318: //212/9DE891800000/CCAPI/ccCallSetContext:
   Context=0x696B9FB8
*Feb 27 00:27:47.322: //209/9DE891800000/CCAPI/ccSaveDialpeerTag:
*Feb 27 00:27:47.322: //212/9DE891800000/AFW_:/AFW_M_Leg_SetExecEnv:
*Feb 27 00:27:47.322: //209//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 4
*Feb 27 00:27:47.322: //-1/9DE891800000/AFW_:LP:EE681ABEBC000:LG212:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 4
*Feb 27 00:27:47.322: //212/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
*Feb 27 00:27:47.322: //212/9DE891800000/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_212
*Feb 27 00:27:47.322: //212/9DE891800000/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 3A type 3
*Feb 27 00:27:47.322: //209//Dest:/DestSetup: Destination setup success
*Feb 27 00:27:47.322: //209//Dest:/AFW_M_Destination_Initiate: attempting call to destination 33332
*Feb 27 00:27:47.322: //209//Call:/CS_Placecall: Call placed to 33332 index 0
*Feb 27 00:27:47.322: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(HANDOFF[4])---------------
*Feb 27 00:27:47.322: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:27:47.322: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.322: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.322: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.322: //209//AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.322: //209//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: DigitCollect_696D9DFC_0_73558152
*Feb 27 00:27:47.322: //209//AFW_:/AFW_Object_RemoveAllListener:
*Feb 27 00:27:47.322: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 4
*Feb 27 00:27:47.322: //-1//AFW_:HN04626888:/AFW_M_Event_Free: ExecEnv objCount: 5
*Feb 27 00:27:47.326: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
*Feb 27 00:27:47.326: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.326: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.326: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:27:47.326: //212/9DE891800000/SIP/Error/ccsip_ipipms_peer_chnl_ind_hdlr: Peer caps is NULL
*Feb 27 00:27:47.330: //212/9DE891800000/CCAPI/cc_api_call_proceeding:
   Interface=0x68263008, Progress Indication=NULL(0)
SIP: (212) Group (a= group line) attribute, level 65535 instance 1 not found.
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.338: //212/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[212][LEG_OUTINIT(7)][Cause(0)]
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:47.338: //212/9DE891800000/SSIN:/AFW_SS_MapEvent:
*Feb 27 00:27:47.338: //-1//SSIN:/AFW_SS_SIP_MapEvent:
*Feb 27 00:27:47.338: //212/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: LEG[212    ][LEG_OUTINIT(7)][Cause(0)]
*Feb 27 00:27:47.338: //212/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.338: //212/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6A37F5E4_0_73576288]  (
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[212][LEG_OUTINIT(7)][Cause(0)]
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.338: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:47.338: //212/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.342: //212/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
*Feb 27 00:27:47.342: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.342: //209//Dest:/AFW_M_Destination_Action:
*Feb 27 00:27:47.342: //209//Dest:/AFW_Destination_Action:
*Feb 27 00:27:47.342: //209//Dest:/OB_FSM_Drive:
*Feb 27 00:27:47.342: //209//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_6A37F5E4_0_73576288 ---> Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.342: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
*Feb 27 00:27:47.342: //209//Dest:/OB_Setting_Proceeding:
*Feb 27 00:27:47.342: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
*Feb 27 00:27:47.342: //209//Dest:/IW_FSM_Drive:
*Feb 27 00:27:47.342: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_proceeding[31])---[C_Action]------
*Feb 27 00:27:47.342: //209//Dest:/IW_InitProc_Proceeding:
*Feb 27 00:27:47.342: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_INIT[1])---------------
*Feb 27 00:27:47.342: //209//Dest:/DestIsEventNotified:
*Feb 27 00:27:47.342: //209//Dest:/DestComplete: peer #:3333 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
*Feb 27 00:27:47.342: //209//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_6A37F5E4_0_73576288 ---> NULL
*Feb 27 00:27:47.342: //212/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.342: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
*Feb 27 00:27:47.350: //212/9DE891800000/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x68263008, Call Id=212
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
*Feb 27 00:27:47.350: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:47.350: //212/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:47.350: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECTED(20)] {
*Feb 27 00:27:47.350: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[212][LEG_OUTPROCEED(8)][Cause(0)]
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:47.354: //212/9DE891800000/SSIN:/AFW_SS_MapEvent:
*Feb 27 00:27:47.354: //-1//SSIN:/AFW_SS_SIP_MapEvent:
*Feb 27 00:27:47.354: //212/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:47.354: //212/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_6A37F5E4_0_73576288]  (
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[212][LEG_OUTPROCEED(8)][Cause(1)]
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:47.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:47.354: //212/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:47.354: //212/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
*Feb 27 00:27:47.354: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.354: //209//Dest:/AFW_M_Destination_Action:
*Feb 27 00:27:47.354: //209//Dest:/AFW_Destination_Action:
*Feb 27 00:27:47.354: //209//Dest:/OB_FSM_Drive:
*Feb 27 00:27:47.354: //209//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_6A37F5E4_0_73576288 ---> Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.354: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_disconnected[20])---[C_Action]------
*Feb 27 00:27:47.354: //209//Dest:/OB_Setting_Disconnected:
*Feb 27 00:27:47.354: //209//Dest:/OBDiscContinue:
*Feb 27 00:27:47.354: //209/9DE891800000/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Feb 27 00:27:47.354: //209//Dest:/resetAppAlertTimer:
*Feb 27 00:27:47.354: //209//Dest:/Dest_AAA_CheckAccounting:
*Feb 27 00:27:47.358: //209//Dest:/Dest_AAA_CheckAccounting: accounting to be enabled for callID=212
*Feb 27 00:27:47.358: //212/9DE891800000/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=212
*Feb 27 00:27:47.358: //212/9DE891800000/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_212
*Feb 27 00:27:47.358: //212/9DE891800000/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_212, Cause 1
*Feb 27 00:27:47.358: //212/9DE891800000/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 3A type 2
*Feb 27 00:27:47.358: //212/9DE891800000/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Feb 27 00:27:47.358: //-1//Dest:/DestStatusFromDiscCause: mapped "unassigned number (1)"(1) to DEST_INVALID_NUMBER(4)
*Feb 27 00:27:47.358: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DISCONNECTING[6])---------------
*Feb 27 00:27:47.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_6A37F5E4_0_73576288 ---> Destination_6A37F5E4_0_73576288
*Feb 27 00:27:47.358: //209//Dest:/IW_FSM_Drive:
*Feb 27 00:27:47.358: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_disconnected[20])---[C_Action]------
*Feb 27 00:27:47.358: //209//Dest:/IW_InitProc_Disconnect:
*Feb 27 00:27:47.358: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_INIT[1])---------------
*Feb 27 00:27:47.358: //209//Dest:/DestIsEventNotified:
*Feb 27 00:27:47.358: //209//Dest:/DestComplete: peer #:3333 IW State IW_STATE_INIT, OB State OB_STATE_DISCONNECTING
*Feb 27 00:27:47.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_6A37F5E4_0_73576288 ---> NULL
*Feb 27 00:27:47.358: //212/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.358: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
*Feb 27 00:27:47.362: //212/9DE891800000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68263008, Tag=0x0, Call Id=212,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
*Feb 27 00:27:47.726: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:27:47.726: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:47.726: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:48.210: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
*Feb 27 00:27:48.210: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:48.210: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:48.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:48.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:48.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:48.214: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:48.214: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:48.214: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:48.350: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
*Feb 27 00:27:48.350: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:48.354: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:48.354: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:48.354: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:48.354: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
*Feb 27 00:27:48.354: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:48.354: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:48.354: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:48.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:48.358: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.358: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:48.358: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:48.358: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:48.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:27:48.358: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:48.358: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 2 Tone Mode 0
*Feb 27 00:27:48.358: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:48.358: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02
*Feb 27 00:27:48.358: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:48.358: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:48.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:27:48.358: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:48.362: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:48.710: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
   Source Call Id=209, Digit=5, DigitBeginFlags=0x0,
*Feb 27 00:27:48.710: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:48.710: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:48.710: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:48.714: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:48.714: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.714: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:48.714: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:48.714: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:48.714: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:48.850: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
   Source Call Id=209, Digit=5, Duration=160,
*Feb 27 00:27:48.850: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:48.854: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:48.854: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:48.854: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:48.854: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
*Feb 27 00:27:48.854: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:48.854: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:48.854: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:48.854: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:48.858: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:48.858: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:48.858: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:48.858: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:48.858: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:27:48.858: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:48.858: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 5 Tone Mode 0
*Feb 27 00:27:48.858: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:48.858: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=025
*Feb 27 00:27:48.858: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:48.858: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:48.858: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:27:48.858: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:48.858: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:49.210: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
   Source Call Id=209, Digit=7, DigitBeginFlags=0x0,
*Feb 27 00:27:49.210: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:49.210: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:49.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:49.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:49.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:49.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:49.214: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:49.214: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:49.214: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:49.350: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
   Source Call Id=209, Digit=7, Duration=160,
*Feb 27 00:27:49.350: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:49.354: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:49.354: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:49.354: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:49.354: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
*Feb 27 00:27:49.354: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:49.354: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:49.354: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:49.354: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:49.358: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:27:49.358: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:49.358: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:49.358: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:49.358: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:49.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:27:49.358: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:49.358: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 7 Tone Mode 0
*Feb 27 00:27:49.358: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:49.358: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=0257
*Feb 27 00:27:49.358: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:49.358: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:49.358: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:27:49.362: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:49.362: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:50.070: //209/9DE891800000/CCAPI/cc_api_call_digit_begin:
   Source Call Id=209, Digit=0, DigitBeginFlags=0x0,
*Feb 27 00:27:50.070: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:50.070: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:50.074: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
*Feb 27 00:27:50.074: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:50.074: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:50.074: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:50.074: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:50.074: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:50.074: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:27:50.210: //209/9DE891800000/CCAPI/cc_api_call_digit_end:
   Source Call Id=209, Digit=0, Duration=160,
*Feb 27 00:27:50.210: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:27:50.214: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:27:50.214: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:27:50.214: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:27:50.214: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
*Feb 27 00:27:50.214: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:27:50.214: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:27:50.214: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:27:50.214: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:27:50.218: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:27:50.218: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:27:50.218: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:27:50.218: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:27:50.218: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:27:50.218: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:27:50.218: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit 0 Tone Mode 0
*Feb 27 00:27:50.218: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:27:50.218: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02570
*Feb 27 00:27:50.218: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:27:50.218: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:27:50.218: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:27:50.218: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:27:50.218: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:00.210: //209/9DE891800000/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:00.210: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:28:00.210: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:28:00.210: //209/9DE891800000/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
*Feb 27 00:28:00.210: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:00.210: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.210: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:28:00.214: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:00.214: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:28:00.214: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.214: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:28:00.214: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:00.214: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:28:00.214: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:28:00.214: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:28:00.214: //209//Digi:/act_DCRunning_Digit: : pLeg 209 Digit T Tone Mode -1
*Feb 27 00:28:00.214: //209//Digi:/DigitCollect_TreatDigit:
*Feb 27 00:28:00.214: //209//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02570T
*Feb 27 00:28:00.214: //209//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
*Feb 27 00:28:00.218: //209//Digi:/DigitCollect_DialPlanMatch: Match single infotype
*Feb 27 00:28:00.218: //209/9DE891800000/AFW_:/AFW_Leg_DigitReportDisable: Current: 0x2 Input: 0x1
*Feb 27 00:28:00.218: //209/9DE891800000/CCAPI/ccCallReportDigits:
*Feb 27 00:28:00.218: //209/9DE891800000/CCAPI/cc_api_call_report_digits_done:
*Feb 27 00:28:00.218: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:28:00.218: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.218: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:00.218: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:00.218: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:28:00.222: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:28:00.222: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:00.222: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:28:00.222: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:00.222: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:00.222: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:28:00.222: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA084_0_73576372
*Feb 27 00:28:00.222: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:28:00.222: //209//Digi:/act_DCRunning_RDone: id=209 Reporting disabled.
*Feb 27 00:28:00.226: //-1//Digi:/DigitCollect_Complete: DC_INVALID_NUMBER. Digits=02570T
*Feb 27 00:28:00.226: //209//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Module_ReturnArgEv:
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[209    ][LEG_INCCONNECTED(5)][Cause(0)]}
*Feb 27 00:28:00.226: //209/9DE891800000/AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 27 00:28:00.226: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA084_0_73576372 ---> NULL
*Feb 27 00:28:00.226: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.226: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DIGITCOLLECT_DONE(228)] {
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 27 00:28:00.226: //209//Digi:/AFW_M_DigitCollect_EventPreProcess:
*Feb 27 00:28:00.226: //209//Digi:/DigitCollectEnd_UpdateStats:
*Feb 27 00:28:00.226: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:00.226: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:00.226: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696DA084_0_73576372]  (
*Feb 27 00:28:00.230: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:28:00.230: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.230: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:00.230: //209//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 27 00:28:00.230: //209/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 27 00:28:00.230: //209//AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:28:00.230: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 1
*Feb 27 00:28:00.230: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:28:00.230: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:28:00.230: //209//AFW_:/AFW_TclModule_DefaultEvHandling:
*Feb 27 00:28:00.230: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(GETDEST[3],ev_collectdigits_done[228])---[act_GotDest]------
*Feb 27 00:28:00.230: //209//TCL :/tcl_PutsObjCmd:
proc act_GotDest
*Feb 27 00:28:00.230: //209//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
*Feb 27 00:28:00.230: //209//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
*Feb 27 00:28:00.230: //209//AFW_:/vtr_ev_status: argc 2 argindex 2
STATUS: cd_006
MAXEXTENSION: 13
*Feb 27 00:28:00.230: //209//TCL :/tcl_InfotagObjCmd:  infotag get con_all
*Feb 27 00:28:00.230: //209//TCL :/tcl_InfotagGetObjCmd: infotag get con_all
*Feb 27 00:28:00.234: //209//AFW_:/vtr_co_all: argc 2
*Feb 27 00:28:00.234: //209//AFW_:/vtr_co_all: EV_CONNECTIONS []
*Feb 27 00:28:00.234: //209//TCL :/tcl_PutsObjCmd:
Call  got event cd_006 collecting destination
*Feb 27 00:28:00.234: //209//TCL :/tcl_InfotagObjCmd:  infotag get evt_dcdigits
*Feb 27 00:28:00.234: //209//TCL :/tcl_InfotagGetObjCmd: infotag get evt_dcdigits
*Feb 27 00:28:00.234: //209//AFW_:/vtr_ev_dcdigits: argc 2
*Feb 27 00:28:00.234: //209//AFW_:/vtr_ev_dcdigits: DCDIGITS [02570]
proc act_Select
*Feb 27 00:28:00.234: //209//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1
*Feb 27 00:28:00.234: //209//Digi:/tcl_LegDigitCollectObjCmd: collectdigits leg_incoming param1
*Feb 27 00:28:00.234: //209//AFW_:/vtd_lg_incoming: argc 3
*Feb 27 00:28:00.234: //209//AFW_:/vtd_lg_incoming: Legs [209 ]
*Feb 27 00:28:00.234: //209//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 27 00:28:00.234: //209//Digi:/C_DigitCollect_Start: Leg=209, Dialplan=True, Diaplanterm=True, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=False, Abortkey=*, Terminationkey=#, Numpatterns=0, Maxdigits=0, Mindigits=0, Interruptprompt=True, InterTimeout=-1000, Initialtimeout=-1000, Mask=0 Hotword=0
*Feb 27 00:28:00.234: //-1//Digi:/AFW_DigitCollect_New:
*Feb 27 00:28:00.238: //-1//Digi:HN0462E1E4:/AFW_DigitCollect_New: DialPlan=TRUE AbortKey=* TermKey=# NumPatts=0
              Enable=FALSE Consume=FALSE InterruptPrompt=TRUE minDigits=0 maxDigits=0 DialPlanTerm=TRUE hotword=0
*Feb 27 00:28:00.238: //-1//AFW_:LP:EE681ABEBC000:HN0462E1E4:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
*Feb 27 00:28:00.238: //209//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 27 00:28:00.238: //209//AFW_:/AFW_M_Module_GetHandle: Module handle: DigitCollect_696DA30C_0_73589220
*Feb 27 00:28:00.238: //209/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module DigitCollect as listener
*Feb 27 00:28:00.238: //209/9DE891800000/Digi:/DigitCollectStart_UpdateStats:
*Feb 27 00:28:00.238: //209//Digi:/DigitCollect_MLPPTuning:
*Feb 27 00:28:00.238: //209//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
*Feb 27 00:28:00.238: //209/9DE891800000/AFW_:/AFW_Leg_TypeAheadGet: no chars in buffer.
*Feb 27 00:28:00.238: //209/9DE891800000/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Feb 27 00:28:00.238: //209/9DE891800000/AFW_:/AFW_Leg_DigitReportEnable: Current: 0x0 Input: 0x2
*Feb 27 00:28:00.238: //209/9DE891800000/CCAPI/ccCallReportDigits:
   (callID=0xD1, digit_event=0x1, enable=TRUE, consume=FALSE)
*Feb 27 00:28:00.238: //209/9DE891800000/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68263008, callID=0xD1, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Feb 27 00:28:00.238: //209//PACK:/tcl_MediaObjCmd:  media play leg_incoming _dest_no_alcanzable.au %s500 _redest.au
*Feb 27 00:28:00.238: //209//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _dest_no_alcanzable.au %s500 _redest.au
*Feb 27 00:28:00.242: //209//AFW_:/vtd_lg_incoming: argc 5
*Feb 27 00:28:00.242: //209//AFW_:/vtd_lg_incoming: Legs [209 ]
*Feb 27 00:28:00.242: //209//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: (3) _dest_no_alcanzable.au %s500 _redest.au
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: Doing : _dest_no_alcanzable.au
*Feb 27 00:28:00.242: //-1//DPM :/mcTokenizerGetNext: savedcharptr=_ endptrptr=_dest_no_alcanzable.au
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: Token : _dest_no_alcanzable.au status 1
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: call dp_mcDQfromFileDynamic() to Handle relative file name
*Feb 27 00:28:00.242: //-1//DPM :DP134:/dp_mcDQfromFileDynamic:  pLanguage=en FileName=_dest_no_alcanzable.au
*Feb 27 00:28:00.242: //-1//DPM :DP134:/dp_mcDQfromURL:  file=flash:en_dest_no_alcanzable.au
*Feb 27 00:28:00.242: //-1//MCM :/mc_createFromFileUrl: Getting a media content: name=en_dest_no_alcanzable.au
    url=flash:en_dest_no_alcanzable.au
    load fast, fetchtimeout=-1
*Feb 27 00:28:00.242: //-1//MCM :MC11:/mc_getFromUrlName: en_dest_no_alcanzable.au on ram
*Feb 27 00:28:00.242: //-1//MCM :/mc_createFromFileUrl: Found a good mc (0x6973E964), RefCount(1)
*Feb 27 00:28:00.242: //-1//DPM :DP134:/dp_mcDQfromURL: mc_createFromFileUrl OK
*Feb 27 00:28:00.242: //-1//DPM :/mcTokenizerGetNext: savedcharptr= endptrptr=
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: Doing : %s500
*Feb 27 00:28:00.242: //-1//DPM :/mcTokenizerGetNext: savedcharptr=% endptrptr=%s500
*Feb 27 00:28:00.242: //-1//DPM :DP134:/pc_mc_addToDynamicS: Token : %s500 status 1
*Feb 27 00:28:00.242: //-1//DPM :DP134:/dp_mcDQfromSilence:  time=500
*Feb 27 00:28:00.242: //-1//DPM :/du_create_silenceDynamicObj:  silence=500
*Feb 27 00:28:00.242: //-1//DPM :/du_create_silenceUrlName: name=silence:500
*Feb 27 00:28:00.246: //-1//DPM :/mcTokenizerGetNext: savedcharptr= endptrptr=
*Feb 27 00:28:00.246: //-1//DPM :DP134:/pc_mc_addToDynamicS: Doing : _redest.au
*Feb 27 00:28:00.246: //-1//DPM :/mcTokenizerGetNext: savedcharptr=_ endptrptr=_redest.au
*Feb 27 00:28:00.246: //-1//DPM :DP134:/pc_mc_addToDynamicS: Token : _redest.au status 1
*Feb 27 00:28:00.246: //-1//DPM :DP134:/pc_mc_addToDynamicS: call dp_mcDQfromFileDynamic() to Handle relative file name
*Feb 27 00:28:00.246: //-1//DPM :DP134:/dp_mcDQfromFileDynamic:  pLanguage=en FileName=_redest.au
*Feb 27 00:28:00.246: //-1//DPM :DP134:/dp_mcDQfromURL:  file=flash:en_redest.au
*Feb 27 00:28:00.246: //-1//MCM :/mc_createFromFileUrl: Getting a media content: name=en_redest.au
    url=flash:en_redest.au
*Feb 27 00:28:00.246: //-1//MCM :MC13:/mc_getFromUrlName: en_redest.au on ram
*Feb 27 00:28:00.246: //-1//MCM :/mc_createFromFileUrl: Found a good mc (0x6A1BB1F8), RefCount(1)
*Feb 27 00:28:00.246: //-1//DPM :DP134:/dp_mcDQfromURL: mc_createFromFileUrl OK
*Feb 27 00:28:00.246: //209//PACK:/Media_Play_Start:
*Feb 27 00:28:00.246: //209//MSW :/msw_synth_get_stream_state: genericStream 0x6847C1B8 is in state MSW_S_IDLE
*Feb 27 00:28:00.246: //-1//MSW :/msw_synth_start:
*Feb 27 00:28:00.246: msw_synth_start: Enter...
*Feb 27 00:28:00.246: //209//MSW :/msw_synth_start: current_stream_id=4, content 0x0, dynamicS 0x6A4236A0, current_state=MSW_S_IDLE
*Feb 27 00:28:00.246: //-1//MSW :/msw_synth_start: msw_synth_start: p_mcDynamicS, We've been given a list of URLs to play.
*Feb 27 00:28:00.246: //-1//MSW :/msw_synth_start:      p_mcDynamicQ is NOT empty
*Feb 27 00:28:00.246: //209//MSW :/msu_synth_partial_play: Media Stream URL
*Feb 27 00:28:00.246: //209/9DE891800000/CCAPI/ccAssociateStream:
   Coder=5, DTMF Relay=1, Vad=0,
   Record Function=0x0, Event Queue=0x68BC8FA8, Stream Context=69619FD4,
   Record Context=0x0, Stream Call Id=210, Call Id=209
   Call Entry(Stream Status=2, Digit Enable=TRUE)
*Feb 27 00:28:00.246: //209//TCL :/tcl_FSMObjCmd:  fsm setstate GETDEST
*Feb 27 00:28:00.250: //209//TCL :/tcl_FSMSetStateObjCmd: setstate setstate GETDEST
*Feb 27 00:28:00.250: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(GETDEST[3])---------------
*Feb 27 00:28:00.250: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:28:00.250: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:00.250: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:00.250: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:00.250: //209//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.250: //209//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: DigitCollect_696DA084_0_73576372
*Feb 27 00:28:00.250: //209//AFW_:/AFW_Object_RemoveAllListener:
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 1
*Feb 27 00:28:00.250: //-1//AFW_:HN0462AFB4:/AFW_M_Event_Free: ExecEnv objCount: 3
*Feb 27 00:28:00.250: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:00.250: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.250: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:28:00.250: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:28:00.250: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:00.254: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:00.254: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA30C_0_73589220]  (
*Feb 27 00:28:00.254: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:00.254: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:28:00.254: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:00.254: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:00.254: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:28:00.254: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA30C_0_73589220
*Feb 27 00:28:00.254: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:28:00.254: //209//Digi:/act_DCRunning_RDone: id=209 Enable succeeded.enable=0 matchDialplan=1 numPatterns=0matchDialplanTerm=1
*Feb 27 00:28:00.254: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA30C_0_73589220 ---> NULL
*Feb 27 00:28:00.254: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.254: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:00.258: //209/9DE891800000/CCAPI/cc_api_call_associated:
   Interface=0x0, CallId=209, Disposition=0
   Play Function=0x63D162C4, Codec=0x5, Vad=0x0
   Media Type=0x3, SPI Context=0x696D6F40, Stream CallId=210
   TX Dynamic Pt=0x0, RX Dynamic Pt=0x0
*Feb 27 00:28:00.258: //209//MSM :LP:MS105:/ms_associateDone:
*Feb 27 00:28:00.258: //209//MSM :/ms_asDone_buginf: callID=0xD1, pVdb=0x68263008,
    disposition=0, playFunc=0x63D162C4,
    codec=0x5=g711ulaw, vad=0,
    mediaType=3, streamAssocID=210
*Feb 27 00:28:00.258: //-1//MCM :MR133:/mc_setup_reader_encaps:  SSRC: 0xA0 SeqNum: 0x1A1A
*Feb 27 00:28:00.258: //209//MSM :/ms_associateDone: First Buf Play at 20:26:29.240 of en_dest_no_alcanzable.au
*Feb 27 00:28:00.258: //209//MSM :/ms_associateDone: 20:26:29.240, Tstart(ply: iSndDly 0)
*Feb 27 00:28:00.258: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:00.258: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.258: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:28:00.262: //209//MSM :/ms_handle_stream_timer: >>ms_start_play()
*Feb 27 00:28:00.262: //209//MSM :/ms_start_play: 20:26:29.244 mgdTstop(ply)
*Feb 27 00:28:00.578: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:00.578: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:00.578: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:28:00.578: //-1//AFW_:/AFW_Process_GetTimerEvent: Process Shutdown: 0x68AB84D8
*Feb 27 00:28:00.578: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
*Feb 27 00:28:03.818: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer: Failed AV set
*Feb 27 00:28:03.822: //209/9DE891800000/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x68263008, Call Id=209
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Feb 27 00:28:03.822: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:03.822: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:28:03.822: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECTED(20)] {
*Feb 27 00:28:03.822: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:03.822: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCCONNECTED(5)][Cause(0)]
*Feb 27 00:28:03.822: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:28:03.822: //209/9DE891800000/SSIN:/AFW_SS_MapEvent:
*Feb 27 00:28:03.822: //-1//SSIN:/AFW_SS_SIP_MapEvent:
*Feb 27 00:28:03.822: //-1//MSW :/msw_synth_bargein:
*Feb 27 00:28:03.826: msw_synth_bargein: genericStream=0x6847C1B8,
               reason=MSW_REASON_DISCONNECTED, current_state=MSW_S_PLAYING
*Feb 27 00:28:03.826: //-1//MSW :/msw_synth_stop: msw_synth_stop: Enter...
*Feb 27 00:28:03.826: //-1//MSW :/msw_synth_stop: genericStream=0x6847C1B8,
               mediaStream=0x69619FD4, rtspStream=0x6847CC3C
               reason=MSW_SYNTH_REASON_DISCONNECTED, current_state=MSW_S_PLAYING
*Feb 27 00:28:03.826: //209//MSW :/msw_synth_stop: msw_synth_stop: call ms_stop_play()...
*Feb 27 00:28:03.826: //209//MSM :/ms_stop_play: mgdTstop at 20:26:32.808 (cause MS_STOP_DISCONNECTED)
*Feb 27 00:28:03.826: //209//MSM :/ms_stop_play: Play Stopped at 20:26:32.808
*Feb 27 00:28:03.826: //209/9DE891800000/CCAPI/ccDisassociateStream:
   Call Entry(Stream Status=1, Digit Enable=TRUE)
*Feb 27 00:28:03.826: //209//MSM :/ms_stop_play: calling CBF for stream_id 4
*Feb 27 00:28:03.826: //209//MSW :/msu_synth_ms_play_complete: context=0x6847C1BC, use_dynamic=1, dynamicElement=0x696DD0CC,
            cause=MS_STOP_DISCONNECTED, stream_id=4, duration=3560, rate=0 proto_code=0
*Feb 27 00:28:03.826: //209//MSW :/msu_synth_ms_play_complete: Ignoring: cur. stream=5, resp. stream=4
*Feb 27 00:28:03.826: //209//MSW :/msw_synth_stop: msw_synth_stop: call reg_invoke_dp_delete_mcDynamicS()
*Feb 27 00:28:03.826: //-1//MCM :MC11:/mc_delete: mc=0x6973E964
*Feb 27 00:28:03.826: //-1//MCM :MC11:/mc_check_background_load: mc(0x6973E964), mc->eof=1
*Feb 27 00:28:03.826: //-1//MCM :MC137:/mc_delete: mc=0x6A2A8C24
*Feb 27 00:28:03.830: //-1//MCM :MC137:/mc_check_background_load: mc(0x6A2A8C24), mc->eof=1
*Feb 27 00:28:03.830: //-1//MCM :MC137:/mc_remove: mc: 0x6A2A8C24
*Feb 27 00:28:03.830: //-1//MCM :MC137:/mc_hold_mc: mc_hold_mc: 0x6A2A8C24
*Feb 27 00:28:03.830: //-1//MCM :MC13:/mc_delete: mc=0x6A1BB1F8
*Feb 27 00:28:03.830: //-1//MCM :MC13:/mc_check_background_load: mc(0x6A1BB1F8), mc->eof=1
*Feb 27 00:28:03.830: //209/9DE891800000/AFW_:/AFW_Leg_MediaCallback:
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_Leg_MediaCallback: pLeg=0x696BF2B8, pModule=0x6A43B178
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_Event_New: Event ID: ev_media_done
*Feb 27 00:28:03.830: //-1//MSW :/msw_mediadone_stats:
*Feb 27 00:28:03.830: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:03.830: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_696DA30C_0_73589220]  (
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(16)]
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:28:03.830: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:03.834: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[209][LEG_INCCONNECTED(5)][Cause(16)]
*Feb 27 00:28:03.834: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:28:03.834: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:03.834: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
*Feb 27 00:28:03.834: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_696DA30C_0_73589220
*Feb 27 00:28:03.834: //209//Digi:/AFW_M_DigitCollect_Action:
*Feb 27 00:28:03.834: //209//Digi:/act_DCRunning_Disconnected:
*Feb 27 00:28:03.834: //-1//Digi:/DigitCollect_Complete: DC_DISCONNECTED. Digits=
*Feb 27 00:28:03.834: //209//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
*Feb 27 00:28:03.834: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done
*Feb 27 00:28:03.834: //209//AFW_:/AFW_Module_ReturnArgEv:
*Feb 27 00:28:03.834: //209//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[209    ][LEG_INCCONNECTED(5)][Cause(16)]}
*Feb 27 00:28:03.834: //209/9DE891800000/AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:28:03.834: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 27 00:28:03.834: //209//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_696DA30C_0_73589220 ---> NULL
*Feb 27 00:28:03.834: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 27 00:28:03.834: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.834: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:28:03.834: //209//AFW_:/AFW_TclModule_DefaultEvHandling:
*Feb 27 00:28:03.834: //209//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(GETDEST[3],ev_disconnected[20])---[act_Cleanup]------
*Feb 27 00:28:03.838: //209//TCL :/tcl_CallObjCmd:  call close
*Feb 27 00:28:03.838: //209//TCL :/tcl_CallCloseObjCmd:  close
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 1
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_ExecEnv_CallClose:  Terminating ExecEnv's root module
*Feb 27 00:28:03.838: //209//AFW_:/AFW_Module_Terminate:  Terminating Module: TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.838: //209//AFW_:/AFW_M_TclModule_Terminate:  Module is in the state: ACTIVE
*Feb 27 00:28:03.838: //209//AFW_:/AFW_Module_Terminate:  Terminating Module: DigitCollect_696DA30C_0_73589220
*Feb 27 00:28:03.838: //209//AFW_:/AFW_FSM_Drive: ACTION END: -------------(GETDEST[3])---------------
*Feb 27 00:28:03.838: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:28:03.838: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.838: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:03.838: //209//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 27 00:28:03.838: //209//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DIGITCOLLECT_DONE(228)] {
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[DigitCollect_696DA30C_0_73589220]  (
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 27 00:28:03.838: //209//Digi:/AFW_M_DigitCollect_EventPreProcess:
*Feb 27 00:28:03.838: //209//Digi:/DigitCollectEnd_UpdateStats:
*Feb 27 00:28:03.838: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:03.838: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:03.838: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:03.842: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_696DA30C_0_73589220]  (
*Feb 27 00:28:03.842: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 27 00:28:03.842: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_INCCONNECTED(5)][Cause(16)]
*Feb 27 00:28:03.842: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:03.842: //209//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 27 00:28:03.842: //209/9DE891800000/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 27 00:28:03.842: //209//AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:28:03.842: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 1
*Feb 27 00:28:03.842: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.842: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:28:03.842: //209//AFW_:/AFW_M_TclModule_Action: Module is Terminating
*Feb 27 00:28:03.842: //209//AFW_:/AFW_TclModule_Cleaner: lastFailureCause 0
*Feb 27 00:28:03.842: //209/9DE891800000/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_209
*Feb 27 00:28:03.842: //209/9DE891800000/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_209, Cause 16
*Feb 27 00:28:03.842: //209/9DE891800000/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 3A type 2
*Feb 27 00:28:03.842: //209/9DE891800000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Feb 27 00:28:03.842: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:28:03.842: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:03.842: //209//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.846: //209//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: DigitCollect_696DA30C_0_73589220
*Feb 27 00:28:03.846: //209//AFW_:/AFW_Object_RemoveAllListener:
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 2, CmdPending 1
*Feb 27 00:28:03.846: //-1//AFW_:HN0462E1E4:/AFW_M_Event_Free: ExecEnv objCount: 2
*Feb 27 00:28:03.846: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
*Feb 27 00:28:03.846: //209//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 27 00:28:03.846: //209//AFW_:/AFW_Process_GetAppQEvent: Received
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:   Event[MSW_EV_SYNTHESIZER(178)] {
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:     MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:       LEG[209][LEG_INCDISCONNECTING(6)][Cause(16)]
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:     )
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Process_GetAppQEvent:   }
*Feb 27 00:28:03.846: //209//AFW_:/AFW_M_TclModule_EventPreProcess:
*Feb 27 00:28:03.846: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.846: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:28:03.846: //209//AFW_:/AFW_M_TclModule_Action: Module is Terminating
*Feb 27 00:28:03.846: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.846: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:28:03.850: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:03.850: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.850: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:28:03.850: //209/9DE891800000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68263008, Tag=0x0, Call Id=209,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Feb 27 00:28:03.854: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 27 00:28:03.854: :cc_free_feature_vsa freeing 6719C918
*Feb 27 00:28:03.854:  vsacount in free is 0
*Feb 27 00:28:03.854: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:03.854: //209/9DE891800000/AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 27 00:28:03.854: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECT_DONE(21)] {
*Feb 27 00:28:03.854: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[209][LEG_INCDISCONNECTING(6)][Cause(16)]
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 27 00:28:03.858: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[209][LEG_DISCONNECTED(12)][Cause(16)]
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_Object_RemoveListener:
*Feb 27 00:28:03.858: //209//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 27 00:28:03.858: //209//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.858: //209//AFW_:/AFW_M_TclModule_Action:
*Feb 27 00:28:03.858: //209//AFW_:/AFW_M_TclModule_Action: Module is Terminating
*Feb 27 00:28:03.858: //-1//AFW_:/AFW_Event_New: Event ID: ev_module_done
*Feb 27 00:28:03.858: //209//AFW_:/AFW_TclModule_ReturnIfDone:  Sending Out APP_EV_TCLMODULE_DONE event
*Feb 27 00:28:03.858: //209//AFW_:/AFW_Module_ReturnArgEv:
*Feb 27 00:28:03.858: //209//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_6A43B178_0_73558128 ---> NULL
*Feb 27 00:28:03.858: //209/9DE891800000/AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.862: //209/9DE891800000/AFW_:/AFW_M_Event_Free:  CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_209
*Feb 27 00:28:03.862: //209/9DE891800000/AFW_:/AFW_Object_RemoveAllListener:
*Feb 27 00:28:03.862: //209//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 0
*Feb 27 00:28:03.862: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 1, CmdPending 0
*Feb 27 00:28:03.862: //209/9DE891800000/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 1
*Feb 27 00:28:03.862: //209/9DE891800000/AFW_:/AFW_M_Leg_Free:
*Feb 27 00:28:03.862: //209//MSW :/msw_destroy:
*Feb 27 00:28:03.862: //-1//MSW :/msw_stop: genericStream=0x6847C1B8,
*Feb 27 00:28:03.862: //-1//MSW :/msw_synth_stop: msw_synth_stop: Enter...
*Feb 27 00:28:03.862: //-1//MSW :/msw_synth_stop: genericStream=0x6847C1B8,
               reason=MSW_SYNTH_REASON_DISCONNECTED, current_state=MSW_S_IDLE
*Feb 27 00:28:03.862: //209//MSW :/msw_synth_stop: Stream not currently active
*Feb 27 00:28:03.862: //-1//MSW :/msw_recrd_stop: genericStream=0x6847C1B8,
               mediaStream=0x6A295288, rtspStream=0x6847CC44
               reason=MSW_RECRD_REASON_DISCONNECTED current_state=MSW_S_IDLE
*Feb 27 00:28:03.862: //-1//MSW :/msw_recrd_stop: Stream not currently active
*Feb 27 00:28:03.862: //-1//MSW :/msw_recog_stop:
*Feb 27 00:28:03.862: msw_recog_stop: genericStream=0x6847C1B8,
               mrcpStream=0x6847CCC8
               reason=MSW_RECOG_REASON_DISCONNECTED, current_state=MSW_S_IDLE
*Feb 27 00:28:03.862: //209//MRCP:/mrcp_destroy_session:
   sess_id=54, type=SYNTHESIZER, fsm context=0x6A2A9F68
*Feb 27 00:28:03.862: //-1//MRCP:/mrcp_get_ev:
   ****>Caller PC=0x636A8408, Count=201, Event=0x696F8B9C
   sess_id=54, type=RECOGNIZER, fsm context=0x696DCF6C
   ****>Caller PC=0x636A8408, Count=202, Event=0x696F8BC4
*Feb 27 00:28:03.862: //209/9DE891800000/AFW_:/AFW_M_Leg_Free: LEG[209    ][LEG_DISCONNECTED(12)][Cause(16)]
*Feb 27 00:28:03.866: //209/9DE891800000/AFW_:/decrementDialPeerCallStats: Decrementing call-stat to [0], dial-peer [5555]
*Feb 27 00:28:03.866: //209//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 0
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 3
*Feb 27 00:28:03.866: //209//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 27 00:28:03.866: //209//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_TCLMODULE_DONE(238)] {
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x681ABEBC][pfp]
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[TclModule_6A43B178_0_73558128]  (
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 27 00:28:03.866: //209//AFW_:/AFW_M_TclModule_EventPreProcess:
*Feb 27 00:28:03.866: //209//AFW_:/AFW_Object_WalkListeners:
*Feb 27 00:28:03.866: //209//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 27 00:28:03.866: //209//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 27 00:28:03.866: //209//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.866: //209//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: TclModule_6A43B178_0_73558128
*Feb 27 00:28:03.866: //209//AFW_:/AFW_Object_RemoveAllListener:
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 0, CmdPending 0
*Feb 27 00:28:03.866: //-1//AFW_:HN04626870:/AFW_M_Event_Free: ExecEnv objCount: 0
*Feb 27 00:28:03.866: //-1//SERV:/AFW_Service_ReleaseExecEnv: Script Name = pfp cache = true calls = 0
*Feb 27 00:28:03.866: //209//AFW_:/AFW_ExecEnv_UnSetRoot: Execenv = 0x681ABEBC
*Feb 27 00:28:03.866: //-1//AFW_:/AFW_Process_UnLock: pProcess(0x68AB8558)=0
*Feb 27 00:28:03.870: //-1//SCRI:/cam_sa_stopped: Instance: [] ExecEnv: 0x681ABEBC
*Feb 27 00:28:03.870: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 27 00:28:03.870: //-1//AFW_:/AFW_M_Event_Free:
*Feb 27 00:28:03.870: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
*Feb 27 00:28:03.870: //209//MRCP:/mrcp_process_events:
   event: SYNTH_LIB_DESTROY SYNTHESIZER
*Feb 27 00:28:03.870: //209//MRCP:/mrcp_fsm_execute:
   (0x6A2A9F68) type=SYNTHESIZER curr[SYNTH_IDLE]
    ev-id[SYNTH_LIB_DESTROY]
    next[SYNTH_IDLE] action=636B4BDC0
*Feb 27 00:28:03.870: //209//MRCP:/act_synth_libdestroy:
*Feb 27 00:28:03.870: //209//MRCP:/mrcp_free_fsm:
*Feb 27 00:28:03.870: //209//MRCP:/mrcp_disconnect_connect_fsm:
   (0x6A3A8AFC)
*Feb 27 00:28:03.870: //-1//MRCP:/mrcp_get_ev:
   ****>Caller PC=0x636AFC38, Count=203, Event=0x696F8BEC
*Feb 27 00:28:03.870: //-1//MRCP:/mrcp_free_ev:
   ---------------->Caller PC=0x636AB1E4, Count=201, Event=0x696F8B9C
   event: RECOG_LIB_DESTROY RECOGNIZER
   (0x696DCF6C) type=RECOGNIZER curr[RECOG_IDLE]
    ev-id[RECOG_LIB_DESTROY]
    next[RECOG_IDLE] action=636B34380
*Feb 27 00:28:03.870: //209//MRCP:/act_recog_libdestroy:
   (0x6719E160)
   ****>Caller PC=0x636AFC38, Count=204, Event=0x696F8C14
   ---------------->Caller PC=0x636AB1E4, Count=202, Event=0x696F8BC4
*Feb 27 00:28:03.874: //209//MRCP:/mrcp_process_events:
   event: LIB_DISCONNECT RESOURCE_NONE
*Feb 27 00:28:03.874: //209//MRCP:/mrcp_fsm_execute:
   (0x6A3A8AFC) type=SYNTHESIZER curr[CONNECT_IDLE]
    ev-id[LIB_DISCONNECT]
    next[CONNECT_IDLE] action=636B28040
*Feb 27 00:28:03.874: //209//MRCP:/act_idle_disconnect:
*Feb 27 00:28:03.874: //209//MRCP:/mrcp_cleanup_connect_fsm:
   connect_fsm(0x6A3A8AFC)
*Feb 27 00:28:03.874: //209//MRCP:/hash_get:
   Table=serverstatus_table, Key=42
*Feb 27 00:28:03.874: //-1//MRCP:/mrcp_free_ev:
   ---------------->Caller PC=0x636AB1E4, Count=203, Event=0x696F8BEC
   (0x6719E160) type=RECOGNIZER curr[CONNECT_IDLE]
   connect_fsm(0x6719E160)
*Feb 27 00:28:03.874: //209//MRCP:/mrcp_free_scb:
   scb=0x6973DEAC
*Feb 27 00:28:03.874: //209//MRCP:/mrcp_create_session_history:
   scb=0x6973DEAC stream=0x0
   No streams in session control block
   ---------------->Caller PC=0x636AB1E4, Count=204, Event=0x696F8C14
Since Dialplan is set to true, digits collected based on your dial plan.
set param1(dialPlan) true
As Yawming suggested you can remove dialplan and try to set maxdigits or patterns based on your requirements.
    set param1(interruptPrompt) true
    set param1(maxDigits) 13
    set param1(initialDigitTimeout) 5
    set param1(terminationKey) #
or
    set pattern(1) "99....."
    set pattern(2) "88....."
    leg collectdigits leg_incoming param1 pattern
    leg collectdigits  param1
Note : You will get different status code cd_005 "The digit collection succeeded with a match to one of the patterns" instead of cd_004 status code.
For more information please refer TCL IVR programming Guide  in below location.
https://developer.cisco.com/site/voice-gateway/documents/api-documents/index.gsp
Raghavendra
Thanks that is ..
