TCL IVR for gateway voice
avelino01
I need help setting up a TCL ivr script on the ISR4351 / K9 router and as I don't know, can anyone help me?
I need to configure a script with these forms, could someone send me some sample, please?
From PSTN -> incoming = welcome audio -> press 1 > other audio lighting text -> forwarded to an extension
        or press 2 > forwards to an extension
Thank you in advance
KiranKL
Could you get a chance to look through these sample scripts shared in this repo.
https://github.com/CiscoDevNet/voice-gateway-api-tcl-vxml-sample-scripts
It it doesn't help, I am sure someone will update you the required information.
Best regards
avelino01
Thank you so much to you shared me repo, but I don't know what I can use for this case.
Alexander Stevenson
@avelino01
Be sure to check out:
Cisco DevNet Automation Exchange
https://developer.cisco.com/network-automation/
Cisco DevNet Code Exchange
https://developer.cisco.com/codeexchange/
