Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hello,I need help setting up a TCL ivr script on the ISR4351 / K9 router and as I don't know, can anyone help me?I need to configure a script with these forms, could someone send me some sample, please? From PSTN -> incoming = welcome audio -> press ...
avelino01 by • Frequent Visitor
  • 2593 Views
  • 3 replies
Dear colleagues, I have the next task: i need to play notification for client when the client is calling to an agent. This is notification from audio file (I am planning to use some java RTP library for this).We have:1. CUCM 12.5, JTAPI 12.52. 4001 D...
NicolayDm by • Visitor
  • 4662 Views
  • 9 replies
So I need to come up with a solution that allows my app to switch over to another CUCM with the smallest possible delay when a server goes down. There's timers on the CiscoJtapiPropertiesspecifically, the heartbeatInterval, and I'm guessing the javaS...
Hello Team,Requirement:When the user makes the outbound call, based on the dialed number area code the calling number area code should change I am trying to use CURRI to meet this requirement and built an HTTP Server using python and tested it using ...
Hi All, We are sending SOAP web service from Automation anywhere towards CUCM and we are getting below error . "Could not parse the WSDL https://10.20.3.85:8443/axl/ for SOAP request." Can anyone 1 guide how we can resolve this issue . Same is workin...
Vinod.s by • Level 6
  • 15949 Views
  • 5 replies
Hi,using jtapi when i receive call i have On incoming callReceived--> Terminal/(P1-callProxy) [BOT3473499480] CiscoTermDeviceStateAlertingEv [#7] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12 DEVICE STATE--> ALERTINGwhen answerReceived--> Termi...
Max Bagnara by • Frequent Visitor
  • 2791 Views
  • 1 replies
Hi all, I'm in the middle of trying to implement silent monitoring.  Everything seems to be in place except for the identifier for the line I'm trying to monitor.  According to this page of the documentation, I have to pass "the permanent lineID of t...
tevans2 by • Frequent Visitor
  • 3340 Views
  • 2 replies
Hello All,  Below is my scenario  Extension A is observed   Caller calls from PSTN to Extension A  Extension A rings and A Rejects the call.I am using call.drop() to reject the call. When I invoke this, the call seems to disconnect and then ring all ...
PVYAPA by • Level 2
  • 2325 Views
  • 1 replies
